I recently made some LED lights for a friend. The lights do a slow fade between two colors and go on either side of a parking garage entry. See the attached pic for a wiring diagram.
The issue is that it seems that sometimes one of the uC's reset in the first 300-500 milliseconds. Before they were installed I noticed that when the power supply was first switched on there was sometimes a little stutter. However, this is causing the lights not to be in synch. It's not a real big deal but I'd like for them to stay close to synchronized. I don't have any communication between the two LED lights so I need them to start at the same time.
I was thinking of putting a 4700uF cap across the hot and ground at each of the lights. Good idea? Should I put a diode between the cap and the power supply as well?
Any ideas are appreciated.
