PIC PWM length capture
Shreder001
Joined Mar 7, 2009
22
I am currently planning to be able to control a motor from a PWM input. Since I am very new to C programing, I am going in steps at a time and using LED's to test. Here is what I have so far:
#include <pic.h>
__CONFIG(FCMDIS & IESODIS & INTIO & MCLRDIS & WDTDIS & UNPROTECT);
//Initialize
unsigned char TIMER_COUNT_LOW; // Holding register for TMR0 low byte
unsigned char TIMER_COUNT_HIGH; // Holding register for TMR0 high byte
main()
OSCCON = 0b00000001; // Internal oscillator for system clock
PORTC = 0x00;
CMCON0 = 0b00000111;
ANSEL = 0x00;
TRISC = 0b00111100;
PR2 = 0b11111111; //Set the PWM period by loading the PR2 register
CCPR1L = 0x00;
T2CON = 0b01011000;
TMR2IF = 0; //clear bit for timer2 module interupt flag
while(TMR2IF == 0) //Wait until timer2 overflows then continue
TRISC = 0x00;
ECCPASE = 1;
PORTA = 0x00;
ANSEL = 0x00;
TRISA = 0b00101000;
T1CON = 0b00010101;
while(1==1) // Start MainLoop
while(RA5 == 1) //Wait until RA5 goes low then continue
while(RA5 == 0) //Wait until RA5 goes high then continue
TMR1H = 0x00;
TMR1L = 0x00;
while(RA5 == 1) //Wait until RA5 goes low again
TMR1H = PORTC;
It starts timer1, then waits untill a low signal on RA5 (PWM input), then a high one, then it initializes timer1 and wait for a low signal. imediatly after that, it puts the timer1 value into a variable and the displays it on PORTC (LED array). I compiled and programmed it succesfully, but it does not seem to be displaying the value, any thoughts? Thanks!!
rjenkins
Joined Nov 6, 2005
1,013
I don't know about the rest of it (not enough coffee yet to think properly), but you have the output line backwards - it is copying the port to the counter rather than the counter to the port.
TMR1H = PORTC;
should be
PORTC = TMR1H;
Note with some PICs you may have to read the low half of the counter before you read the high half - The high read is from a latch, saved by the low read so the counter changing between the two reads does no t mess up the data.
Shreder001
Joined Mar 7, 2009
22
I switched them, still nothing. I forgot to mention some of the program I included is for future sections of it (PWM output to motor).
rjenkins
Joined Nov 6, 2005
1,013
It just means you are reading it as that's what the chip needs, rather than because you need the result.
If you were using a variable to store the counter high byte, you could have
char countval;
countval = TMR1L;
countval = TMR1H;
The first one is the dummy, the data is overwritten by the second one, but it does the operation the chip needs, storing the counter high value in the latch.
You don't mention exactly which PIC you are using, so I cannot be sure of the specific requirements for your device.
rjenkins
Joined Nov 6, 2005
1,013
OK, that chip appears to have only a simple timer without the latching system.
A simple read should work..
I don't have time to work through it just now, I will try to get back later.
