PIC programming
Discussion in 'Embedded Systems and Microcontrollers' started by bets90, Jan 20, 2011.
  1. bets90
    Jan 20, 2011
    Hi i am new for PIC micro-controllers, can anyone tell me how to interface it with lcd display and about its ADC pins.. please i need help in short time... also add about keypad interfacing... i' have proteus simulator and micro C compiler... and i will use PIC 16F877A
  2. spinnaker
    Oct 29, 2009
    5,065
    1,162
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
    I'd suggest getting a C compiler first, then getting an LED blinking, so you are comfortable with the ports and registers, and get an understanding of how fast the code runs (very, very fast).
    The reason I bring up speed is writing to an LCD is a "slow" process, and the timing needs to be right. It's still not rocket science, and a good compiler (MikroC or BoostC) provide libraries to do all the dirty work for you. Another reason to pick a compiler or two, then learn all about it in detail to find a "preferred" compiler. Things will seem much simpler after that point.
    If you don't know C, Mikro and Boost provide BASIC language, as well as some other (sort of expensive) BASIC only compilers.
  4. rajbex
    Nov 2, 2009
    22
