1. txfirefighter4721
    Jul 30, 2009
    13
    OK. If you remember I'm building an underwater ROV. I have decided to go into very unkown territory. I would like to learn about PIC's and how to program them. Does anyone know a good place to start? Ive searched and really havent too much luck. Probably not putting in the correct phrases. Thanks in advance.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Try here: http://tutor.al-williams.com/pic-intro.html
    [eta]
    Actually, that tutorial is very dated. The PIC instructions portion is OK, but you need more of an intro.
    If you don't have any PICs or a way to program them, you might consider a PICkit 2 Debug Express, about $50 from Microchip Direct. It comes with a surface-mount PIC16F887 on a prototype board. (The PIC16F88x series are basically replacing the PIC16F87x series; they aren't identical, but are much cheaper)
    The PICkit 1 costs less (around $35), but it just programs the lower pin count PICs (up to 14 pins).
    You can download the Microchip MPLAB from their website for free.
  3. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
  4. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    As learning curves go I'd recommend a PICkit2 or compatible like my Junebug (shameless plug :rolleyes:) and the very easy to learn Swordfish BASIC compiler (the SE version is free)
    The Arduino uses a C like language and uses a bootloader. (of course there are C compilers for PICs too)
