PIC Programming in 4GL
Discussion in 'Programmer's Corner' started by jmeredith, Nov 25, 2009.
  1. jmeredith
    Nov 18, 2009
    23
    Are there any PICs / Microcontrollers that can be programmed in a 4GL?
    -Jason
  2. AlexR
    Jan 16, 2008
    735
    54
    What you really should be asking is whether there is a 4GL to PIC cross-compiler available. If you have a working cross-compiler you should be able to use it for any PIC. But I certainly don't know of any.
    More to the point does anyone still use 4GL for anything other than database programming?
  3. jmeredith
    Nov 18, 2009
    23
    I am just getting into the curious world of microcontollers and I have used ASP/VBScript quite a bit... My C++ is a bit rusty and I was hoping to use what I already knew.
    I guess I will likely need to get my college C++ book out and brush up on it
    thanks
    -Jason
  4. AlexR
    Jan 16, 2008
    735
    54
    There is not that much C++ around for microcontrollers and most chips don't have the resources to utilise the full power of C++. The language of choice for microcontrollers at present is plain old C and there are plenty versions to choose from.
