PIC Programming help (Urgent)
Discussion in 'Embedded Systems and Microcontrollers' started by prwp, Jul 10, 2008.
  1. prwp
    Jul 10, 2008
    I need help on these programming code. The programming i am using is PIC18F452.
    When you start the program, LCD Display the following message (first line)
    name is here.
    The Message should be repeatedly cleared off and redisplayed until push button, S3 (at RB0) is pressed. ( to show stationary display)
    When you press the switch, the second message "Hi" must be displayed on the 2nd line.
    When you press the switch, the second message "and welcome back" must be displayed on the 2nd line.
    When you press the switch again, it will return to start up.
    I need the programming code and i hope there will be a kind person to help me out. Thank you for your help.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    This appears to be an assignment. We'll leave it here, but it really should be treated as homework. Our standard notice is:
    The Homework Help section asks that you post up the work you have done so we can see it and find where you went wrong, or suggest better approaches. We will not do all your work for you, no matter how little time is left before it must be submitted.
    If you are in doubt about how to structure your post and what to include please read this thread.
    Thank you.
