PIC programming help in mikroC
Discussion in 'Embedded Systems and Microcontrollers' started by thebenman, Mar 16, 2014.
  1. thebenman
    Jan 26, 2014
    27
    Hey,
    I basically want to trigger the mosfets in a DC-DC converter.I simply want to program the PIC16F877A to generate PWM signals with a certain delay for triggering the mosfets.However,when i tried to run the program i got an error-"22 304 error: End of input within #if (#ifdef) section started at line 1 } 1 error in preprocessor. D:\PIC\final.c" .I have attached the code below too,
    Code ( (Unknown Language)):
    1.
    2. #if defined (__PCB__)
    3. #include <16f877a.h>
    4. #fuses HS,NOWDT,NOPROTECT
    5. #use delay(clock=20000000)
    6. #elif defined(__PCM__)
    7. #include <16F877a.h>
    8. #fuses HS,NOWDT,NOPROTECT,NOLVP
    9. #use delay(clock=20000000)
    10. void main()
    11. {
    12. while(1)
    13. {
    14. output_d(0x55);
    15. delay_us(10);
    16. output_d(0x00);
    17. delay_us(2);
    18. output_d(0xaa);
    19. delay_us(10);
    20. output_d(0x00);
    21. delay_us(2);
    22. }
    23. }
    24.
  2. spinnaker
    Oct 29, 2009
    5,089
    1,185
    Where is your #endif????
  3. spinnaker
    Oct 29, 2009
    5,089
    1,185
    And this should be in the embedded forum.
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    I have moved the thread
    Bertus
  5. thebenman
    Jan 26, 2014
    27
    Hey,
    Thanks for the quick reply,as i did not program this myself i am not quite sure where the end if statement must come.Could you please elaborate.
    Thanks.
  6. ErnieM
    Apr 24, 2011
    7,440
    1,627
    It probably goes just before the "void main()" line, but one never knows when borrowing the code exactly what anything really does, right?
    That's why people don't study how to borrow code, they study how to write code.
    Papabravo likes this.
  7. spinnaker
    Oct 29, 2009
    5,089
    1,185
    Well said.
  8. spinnaker
    Oct 29, 2009
    5,089
    1,185
    Actually it probably does not go there either. What I would do is to remove the #if statement. That technique is used to avoid loading the header file more than once for a given source file. Obvious this is not a header file or at least it better not be.
  9. ErnieM
    Apr 24, 2011
    7,440
    1,627
    After careful consideration of your comments I still stand by mine.
    The technique you think you see is not being used here. The code is being conditionally compiled for two different platforms.
  10. spinnaker
    Oct 29, 2009
    5,089
    1,185
    You might be right. I was assuming #if defined (__PCB__) was the header file but after looking at it again I think you're correct.
  11. thebenman
    Jan 26, 2014
    27
    Yes,i do believe that it is being compiled for two different conditions follow the if statement and the elif statement.However,even as i read the mikroC documentation i am unable to find any reference to such statement as "defined" explained in the documentation.
  12. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    Isn't so dramatic most C compilers support it this way.
    After all just a LVP fuse is set or not- how about to remove it alltogether?
    In the MPLABX documentation it actually can be found explained. I think even the assembler supports it.
    Not aware of any modern programming language (C related) that DOES NOT support it. It's similar to #include.
  13. thebenman
    Jan 26, 2014
    27
    Could you explain what exactly the statements before the void main() statement does ? That would help clear the error :)
  14. shteii01
    Feb 19, 2010
    3,507
    512
    According to example here: http://en.wikipedia.org/wiki/C_preprocessor#Conditional_compilation
    #ifdef __unix__ /* __unix__ is usually defined by compilers targeting Unix systems */
    # include <unistd.h>
    #elif defined _WIN32 /* _Win32 is usually defined by compilers targeting 32 or 64 bit Windows systems */
    # include <windows.h>
    #endif
    You are missing #endif
  15. CVMichael
    Aug 3, 2007
    416
    17
    This code is not for MikroC...
    In MikroC, you include libraries from the pane on the right, you just checkmark them. The clock speed you select in the settings (or tools?) menu (I am at work now, don't remember exactly). There is not such thing as "#fuses" in mikroC...
    For "output_d", you will have to find the equivalent... is the microcontroller connected to a display? If you want to write a byte to the 8 pins on port D, then you just do:
    PORTD = 0x55;
    So you can remove ALL the pre-compiler code there (the code that starts with #), and you just leave the void main(), then it will work (it will compile at least), but you still need the correct settings for the microcontroller to actually make it run...
  16. spinnaker
    Oct 29, 2009
    5,089
    1,185
    If you are asking a question like that then it is obvious you know absolutely nothing about C programming and answering that question will only lead to more questions. It is way beyond the scope of this forum to teach basic C programming.
    My suggestion is forget about micro controllers for now and lean C. There are many tutorials on the internet. Once you understand C then you can tackle micros.
    Here is are halfway decent lessons
    http://www.mikroe.com/products/view/285/book-pic-microcontrollers-programming-in-c/
    and in Mikro C.
  17. thebenman
    Jan 26, 2014
    27
    Hey,
    Yeah,the code is not for mikroC although i am still wondering on which compiler it might work.However,i had written an equivalent code on mikroC where i want the desiered PWM output from the 19,20th pin of 16F877A-each apart from each other by a delay of 200 milliseconds.I was not able to achieve my goal as both the PWM are generated at the same time when i ran it in proteus simulation.I am attaching the code below
    1.
    2. void main()
    3. {
    4.     PORTD=0;                   //Configure PORT D as output
    5.     TRISD=0;
    6.     PWM1_Init(50000);          //Set freq=50Khz
    7.     PWM2_Init(50000);
    8.     PWM1_Set_Duty(127);        //Set duty cycle=50%
    9.     PWM2_Set_Duty(127);
    10.     PWM1_Start();                       // start PWM1
    11.     Delay_ms(200);                      //aprart each other by 200 milliseconds
    12.     PWM2_Start();
    13.
    14. }
  18. CVMichael
    Aug 3, 2007
    416
    17
    You have to create a loop to keep the microcontroller running, otherwise it will keep resetting.
    Something like:
    1.
    2. void main()
    3. {
    5.     TRISD=0;
    12.     PWM2_Start();
    13.
    14.     do{
    15.         Delay_ms(1);
    16.     }while(1);
    17. }
    18.
  19. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Removing the #if would be just as deadly because of the #elif still hanging in the breeze. With apologies to Bill Maher:
    New Rules:
    Don't borrow someone else's code, screw up the transcribing, and come here whining for help.
  20. hexreader
    Apr 16, 2011
    250
    82
    This is true for many compilers, but not true for MikroC Pro, which automatically inserts "while(1);" or some equivalent at the end of every program.
    Still good practice to do it anyway, in case of porting to another compiler.
    Sorry to be pedantic :)
    ... but you make a good point, that the first 7 lines of code starting with '#' have no relevance to mikroC pro and need to be deleted.
    Luckily the OP is asking the same questions on the mikroE forum, where the ME experts are.
