PIC Programmers + PIC16F1827
Discussion in 'General Electronics Chat' started by bfiche, Jun 25, 2012.
  1. bfiche
    Mar 30, 2011
    Hi...
    Is there a programmer compatible (that really works) with PIC16F1827?
    Thanks, in advance.
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Sure;). The programmer that really works is the Microchip PICKIT 3 programmer ( or clones). If you are on a budget maybe your PIC is compatible with the PICKIT 2 programmer. This cost somewhat less than the PICKIT 3. But support less PICs than the PICKIT 3, that should support almost every PIC based on flash memory
  3. bfiche
    Mar 30, 2011
    Thanks for the quick reply.
    I have JDM (serial programmer) and VT134, but they do not support PIC16F1827. And both have a zif-socket.
    PICKIT 3 has no zif-socket, I think... It must be programmed "in circuit"?
    I found that programmer in farnell:
    http://pt.farnell.com/microchip/dv164131/debug-kit-express-pickit-3/dp/1686530
  4. t06afre
    May 11, 2009
    5,939
    1,222
    To program any flash based PIC. You will need only 5 wires. ZIF sockets are not needed. Those who sell PICKITs clones/programmers often try to sell you some kind of ZIF socket board also. But it is not needed. They like to do it. To get most of your money. If you are on budget. Get a PICKIT 3 only with no demo board http://www.microchipdirect.com/ProductSearch.aspx?Keywords=PG164130
  5. ErnieM
    Apr 24, 2011
    7,442
    1,628
  6. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    PICKIT3 + MPLABX = working solution.
    ICSP see attached picture.
  7. bfiche
    Mar 30, 2011
    Thank you all. I'll buy PICKIT 3. I've been seeing the datasheet and it seems a good choice.
    When I do the PCBs with my PICs I will put on them a socket (5 pin/wires) to connect to the programmer.
    Bye (until next question) ;).
    (sorry my English)
