PIC programmer/development
Discussion in 'Embedded Systems and Microcontrollers' started by Jassper, Oct 2, 2008.
  1. Jassper
    Thread Starter Active Member
    Sep 24, 2008
    84
    I'm looking for a good PIC programmer/development board.
    One I have located is very cheap, but requires assembly (no problem there) the other is very expensive.
    Cheap http://www.apogeekits.com/pic_lab.htm
    Expensive http://www.ccsinfo.com/product_info.php?products_id=16F887kit
    Is the cheap one too cheap and is the expensive one worth the money? I know the higher cost one comes with a bit more stuff.
    This is what I am working on, I need to read voltage levels between 0.4 volts and 5.0 volts, and communicate this info via RS-232 I need at least 4 Analog ports.
    Are these kits any benefit, or can you recommend a different approach?
  2. Jassper
    Sep 24, 2008
    84
    Let me ask this a different way,
    What "Getting Started Kit" for Micro controller do any of you recommend that will cover analog ports and RS-232, and what Micros have at least 4 analog inputs?
  3. FastEddie
    Jul 14, 2007
    35
    I'm not sure if this is what you're looking for but I got one of these about 3 or 4 months ago. http://www.mikroe.com/en/offer/I got the Basic version but you can also get it in C and Pascal. It's easy enough to use. I haven't tried the rs-232 yet. The only downside I had was that since it ships from overseas it took a long time to receive it.
  4. Jassper
    Sep 24, 2008
    84
    Hay thanks for the link, those look like some very nice boards and they come with with everything needed. I'll check them out further.
