PIC Programmer circuit
Discussion in 'Computing and Networks' started by ect_09, Aug 17, 2012.
  1. ect_09
    May 6, 2012
    180
    hello!!!
    i want to make pic programmer for pic18f458 .
    i need the circuit and pcb with serial port..
    please it urgent..
    waiting!!!!
  2. nerdegutta
    Dec 15, 2009
    2,565
    805
  3. ErnieM
    Apr 24, 2011
    7,435
    1,625
    Don't do that. Don't make a programmer. You cannot make one cheaper then you can buy a complete assembled and tested programmer.
    Especially if you are just starting out in micro controllers building your own programmer is a path that leads to madness.
    A PICkit2 is $34.99 USD.
  4. ect_09
    May 6, 2012
    180
    but i am from pakistan.it is not available in my city..this is the reason i want to make it own.
    and
    @nerdegutta:
    sir its a google search.in this way i have to work a lot.
    please help me with the specific PCB and schematics.if you have...
    please...
  5. nerdegutta
    Dec 15, 2009
    2,565
    805
    Yes, it's a google search. You said you needed circuit and pcb. That google search shows circuits and pcb. :)
    ... and ? No one is going to do it for you. You have to do it yourself. With guidance from the forum. :)
    I've tried building my own programmers, with no luck. Do what ErnieM said. Buy one. Buy the PicKit3, or PicKit2. Or you can try to get one from this company.
    Good luck with your projects.:)
  6. ect_09
    May 6, 2012
    180
    i know.
    your link was the general.no specific one.
    this is the reason i told you that i have to work alot.
    firstly i have to draw circuit.
    then pcb
    then work for it....
  7. nerdegutta
    Dec 15, 2009
    2,565
    805
    Have you tried to google "PicKit clone circuit"?
  8. absf
    Dec 29, 2010
    1,493
    374
    A lot of the simpler programmers that work on serial and parallel ports on the PC might not be able to program the newer PIC chips. If you're programming the 12Fxxx or 16Fxxx series PIC, I would recommend them without hesitation.
    One of them is here:
    http://www.qsl.net/dl4yhf/winpic/
    If you dont already owned a PIC programmer you wont be able to construct the USB pickit clone here:
    http://tomeko.net/pickit2.php?lang=en
    As you can see the USB programmer is using an 18F pic to program another pic.
    That's why most here suggested that you buy a ready made USB ICSP programmer. They are considered quite cheap and a good investment if you know what a PICKIT 2 or 3 can do. If you cannot afford the genuine one from microchip you can get a pickit clone from India or the one here which I am using now:
    http://www.cytron.com.my/listProducts.php?actionURL=&txtSearch=uic&txtCommentBox=&txtCommentEmail=
    Allen
  9. ect_09
    May 6, 2012
    180
    Its nice.
    i should try..
    Thanks!!
  10. BillO
    Distinguished Member
    Nov 24, 2008
    985
    136
    These guy's are in Pakistan.
  11. ect_09
    May 6, 2012
    180
    yup,i'm from pakistan...
  12. absf
    Dec 29, 2010
    1,493
    374
    I think you've mis-understood BillO.....
    Did you click on the link pointed to at These ???
    Allen
