PIC Problem
Discussion in 'The Projects Forum' started by RodneyB, Apr 28, 2012.
  1. RodneyB
    Thread Starter Active Member
    Apr 28, 2012
    643
    13
    I am asking for some help, I am building a PIC development board and its not working and I suspect the crystal. I do not have an oscilloscope and dont know how to test it. In addition to this I have used 100P capacitors and the circuit shows 68P with a 32Khz Crystal. Any advice you can give would be greatly appreciated
  2. debjit625
    Apr 17, 2010
    790
    186
    Help us to help you,provide a proper circuit diagram for your development board.
    Crystal are not that costly,change with another one to test it.Many times people doesn't set the correct configuration bits settings,check if you have properly configured all the configuration bits.
    Good Luck
