PIC operation failed
Discussion in 'Embedded Systems and Microcontrollers' started by jurinov, Jul 4, 2016.
  1. jurinov
    Nov 17, 2015
    I use a PICkit 3 and a PIC32 MX795F 512L, but the device wasn't detected. I have tried PIC18F4520 and it was working well.
    I selected manually the right device and tried to import and write hex file, but the reaction was: "operation failed". The PIC32 device family can't be recognised at all.
    Could you help me please what can be the problem?
  2. NorthGuy
    Jun 28, 2014
    611
    121
    PICkit3 is hardware. What software do you use? If it lets you select PIC32MX795F512L then apparently it knows that such device exists. I would suspect the connection.
  3. jurinov
    Nov 17, 2015
    Hi, I'm using PICkit 3 (tried more than one versions), and also MPlab IDE (8.92) also.
    I did the wiring according to this schematic, although i emmitted the parts I did not circle, and used some other values.
  4. Picbuster
    Member
    Dec 2, 2013
    391
    53
    Hi, what is your power source; pic kit or its own supply?
    All , at the first glance looks right.
    Picbuster
  5. jurinov
    Nov 17, 2015
    Hi! thanx for the reply guys it started to work, after i did some soldering, (the source was from my pc 3.3v), probably my breadboard gave up, but now it works like a charm :)
    atferrari likes this.
  6. NorthGuy
    Jun 28, 2014
    611
    121
    Congratulations!
