To seniors,
I've been given a project of making a mono-frequency analyzer (frequency counter) of input range 1kHz - 100kHz.
I'm thinking of using a Microchip PIC model 16F874/877A to analyze the input waveform. The input would be a +/-15V AC voltage.
The analyzed frequency would shown on a LCD screen. Furthermore, there will be 4 output pins which the user should define their ranges of frequency (e.g: pin1: 1k~25kHz, pin2: 25kHz~50kHz,...), If the detected frequency falls into 1 of the 4 range pins, the relevant pin would be "ON", otherwise would give nothing. (e.g. detected 45kHz; pin2 ON)
My questions:
(1) Is PIC16F877A suitable for the job?
(2) As for the frequency analyze part, my senior told me that the internal clock inside the PIC would do the comparison with the input signal, but i thought an external crystal clock would do the job, is a crystal necessary?
(3) I'm using MPLab.IDE to write the program code, but i don't know if the b/w LCD screen/keypad would be compatible with the program, is there any way i could know if a new LCD screen/keypad (haven't buy) can be recognisable by the program, or is there any special command/program for the screen/keypad?
(4) Other than using a 12-buttons keypad, is there any other possible way which can be used for the same purpose but simpler programming code?
This is because my senior told me that the program for 12-buttons matrix keypad is quite complicated.
Thanks a lot for any help/suggestions/ideas!
My questions:
