PIC Microcontroller Programming help
Discussion in 'Embedded Systems and Microcontrollers' started by withloveshyam, Apr 2, 2011.
  1. withloveshyam
    Mar 20, 2010
    20
  2. eblc1388
    Nov 28, 2008
    1,542
    102
    The PIC codes is written by a qualified software programmer and is very well commented. It also looks a lot like something that is used inside some sort of commercial product that communicate using the AC mains.
    How did you find the piece of code in the first place?
  3. entropy01
    Apr 6, 2011
    LOL, thats funny
  4. Markd77
    Sep 7, 2009
    2,803
    594
    Maybe he found the answer on another forum. When he posted it I had a search and the question had been posted to another 3 or 4 forums.
  5. eblc1388
    Nov 28, 2008
    1,542
    102
    He had completely deleted the same posting on various forums and seek help of moderator of one forum to remove the attachment too. That moderator cited the reason being some copyright issues.
  6. Barnaby Walters
    Member
    Mar 2, 2011
    103
    Just out of interest… How could you tell it was written by a professional? You seemed very certain (and suitably suspicious!) in your first post.
    Thanks,
    Barnaby
  7. t06afre
    May 11, 2009
    5,939
    1,222
    As I can remember the code was well documented. And this could not have been done by the OP. I suspect withloveshyam. Is a student and someone in his class found out and threaten to tell his teacher.....
  8. eblc1388
    Nov 28, 2008
    1,542
    102
    The assembly code has several #if..#else..#elseif constructs which mostly used only by professional to cater their code for different occasions like debugging options.
    This along with the detailed concise commenting led me to the conclusion the code is done by someone professional.
    Barnaby Walters likes this.
  9. Barnaby Walters
    Member
    Mar 2, 2011
    103
    Ok, that makes sense. When you replied with such certainty I initially thought that you or someone you knew had written the code, and you were trying to figure out where this chap had got it from!
    Thanks,
    Barnaby
