PIC master and slave
Discussion in 'Embedded Systems and Microcontrollers' started by RG23, Sep 28, 2012.
  1. RG23
    Thread Starter Active Member
    Dec 6, 2010
    301
    I am using two pic controllers
    i am able to read the data form the slave to master
    but I am not able to write the data from master to slave
    When I send the data 0x15 from the master I see that on the oscilloscope correctly
    but somehow I am not entering the label_transmit1 subroutine
    I tried to set PORTC,2 in the main part of the program
    and reset it as bcf PORTC,2 just to check if I enter that particular subroutine but it stays high
    if anyone has an idea please let me know
  2. RG23
    Dec 6, 2010
    301
    When the master sends the data to the slave
    I check if PIR1 bit 3 is high first
    Then I check for D/A bit of SSPSTAT
    and then the R/W bit of SSPSTAT
    is it the correct approach?
