PIC.h
Discussion in 'Programmer's Corner' started by sportsfan27, Jul 14, 2009.
  1. sportsfan27
    Thread Starter Active Member
    Jan 29, 2009
    43
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    As far as I can see the pic.h files are parts of a larger program.
    The first is a part of a kind of particle analysis system.
    The second is a part of thr torsion operating system.
    The third website gives an error.
    Greetings,
    Bertus
  3. sportsfan27
    Jan 29, 2009
    43
    So which one should I use for a simple PIC program?
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The files ending with .h are header files for a larger C or C++ program.
    The header files are used to link the program parts together.
    I do not know wich one can apply to your needs.
    Greetings.
    Bertus
    PS to the others please correct me if I am wrong.
    I am not to well known with programming.
  5. DumboFixer
    Feb 10, 2009
    219
    34
    I wouldn't dare :)
    Anyway, you are correct.
    Sportsfan27, you assembler/compiler should come with a suitable header file.
  6. millwood
    Guest
    what header files to use depends on your development environment and toolchain used.
