PIC frequency
Discussion in 'General Electronics Chat' started by dhruv1128, Aug 10, 2014.
  1. dhruv1128
    Jun 28, 2014
    6
    Hello all,
    I am using pic18f4550 and i am interfacing a crystal of 20Mhz. I want to know the execution time of 1 instruction cycle. I am having a great confusion. Please help me.
    Also, suggest me the method to do so please.
    Thanking you in advance
  2. blah2222
    May 3, 2010
    565
    33
    From page 387 of the datasheet:
    Instruction Cycle Time (Tcy) = 4*Tosc = 4/Fosc with a minimum of 83.3 ns.
    Fosc for you is 20 MHz. I'm sure you can do the rest...
    dhruv1128 likes this.
  3. Brownout
    Jan 10, 2012
    2,375
    998
    1 instruction cycle should take 4/(20*10^6) seconds.
  4. NorthGuy
    Jun 28, 2014
    611
    121
    I'll go even further: 200 ns
  5. atferrari
    Jan 6, 2004
    2,666
    784
    In case of doubt, using the simulator, MPLAB Sim, just by stepping through a simple series of NOPs, you could see how much time is spent in each instruction cycle.
    Look for the "stopwatch" function.
  6. Sensacell
    Jun 19, 2012
    1,183
    276
    Very common problem, there are so many clocking options to consider.
    I usually test the clock frequency like this:
    loop:
    btg LATX,X ;toggle IO pin state
    bra loop
    Measure the frequency of the output to confirm the clock speed.
    This saves much confusion about what is really going on, it's easy to get confused and set the clock bits wrong, then drive yourself insane trying to set a UART Baud rate.
  7. ErnieM
    Apr 24, 2011
    7,437
    1,626
    But how long is a bra? I go a another step when pounding this out:
    loop:
    bfs LATX,X ;toggle IO pin state
    bcs LATX,X ;toggle IO pin state
    bra loop
    Then I look with a scope, and it is right there in my face what the instruction rate is.
  8. Alec_t
    Sep 17, 2013
    5,973
    1,135
    Depends on the lady it's designed for :).
    atferrari and blah2222 like this.
