PIC external clock help
Discussion in 'The Projects Forum' started by victorment, Sep 23, 2011.
  1. victorment
    Jul 4, 2010
    52
    Does the external clock value and the clock value that you had program to the PIC must match?
    I have programmed a PIC 16f877A using Flowcode and set the clock speed in 3276800. I load the program to the PIC and verify and it was successful. After then I interface the pic, I connected the supply vdd, vss and a 4MHZ crystal oscillator and the leds but the PIC won't run. The leds won't light. What seem to be the problem can you help me?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Try removing the xtal oscillator. Did you use the proper caps for the oscillator?
    You really should have programmed it with the right frequency.
  3. BMorse
    Sep 26, 2009
    2,675
    234
    Yes they have to match, and can you post a copy of the circuit schematic for your circuit?
  4. victorment
    Jul 4, 2010
    52
  5. ErnieM
    Apr 24, 2011
    7,437
    1,626
    Well, it depends. Flowcode (and several other programming packages) only need that value so they can time delays and such that are set by code. Meaning of you told it you have a 1uS instruction rate and you use a 1mS delay, it will waste 1,000 instructions to make that delay. If you then go and use say a .1uS instruction rate (10x higher frequency) then you will only get a .1mS delay.
    The code will run, but the results may not be any good. That will vary on why you needed that delay.
    That said, if you are just say lighting a LED when it starts that should work just fine as no delays are involved.
    Your schematic looks fine, only exception I see offhand is you can't do in circuit programming with the way you have MCLR set up.
    You should look at how you set the configuration bits as those tell the processor what kind of oscillator you are using, if that is set wrong it doesn't work.
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Did you turn off the internal oscillator when you connected the xtal?
  7. victorment
    Jul 4, 2010
    52
    I don't know. I am new to PIC. Is it in the programming part of the PIC or Loading the program to the PIC?
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Post your source code.
    Click the "Go Advanced" button, then select the "#" on the menu bar, and then paste your source code in between the code blocks.
  9. ErnieM
    Apr 24, 2011
    7,437
    1,626
    This PIC has no internal oscillator (or I would have suggested for the OP to use it as a sanity check).
    victorment: look in your Flowcode help file for configuration bits. It has to be there, along with how to set them. We can help you get what you set them to, you need to find how you set them.
  10. victorment
    Jul 4, 2010
    52
    Here is the C Code:
    //** File name: C:\Users\Public\Documents\Vic PIC\ADC for design project.c
    //** Generated by: Flowcode v4.2.3.58
    //** Date: Sunday, September 25, 2011 20:14:20
    //** Licence: Professional
    //** Registered to: victory
    //** http://www.matrixmultimedia.com
    #define MX_PIC
    //Defines for microcontroller
    #define P16F877A
    #define MX_EE
    #define MX_EE_TYPE2
    #define MX_EE_SIZE 256
    #define MX_SPI
    #define MX_SPI_C
    #define MX_SPI_SDI 4
    #define MX_SPI_SDO 5
    #define MX_SPI_SCK 3
    #define MX_UART
    #define MX_UART_C
    #define MX_UART_TX 6
    #define MX_UART_RX 7
    #define MX_I2C
    #define MX_MI2C
    #define MX_I2C_C
    #define MX_I2C_SDA 4
    #define MX_I2C_SCL 3
    #define MX_PWM
    #define MX_PWM_CNT 2
    #define MX_PWM_TRIS1 trisc
    #define MX_PWM_1 2
    #define MX_PWM_TRIS2 trisc
    #define MX_PWM_2 1
    //Functions
    #define MX_CLK_SPEED 4000000
    #ifdef _BOOSTC
    #include <system.h>
    #endif
    #ifdef HI_TECH_C
    #include <pic.h>
    #endif
    //Configuration data
    #ifdef _BOOSTC
    #pragma DATA 0x2007, 0x3fb1
    #endif
    #ifdef HI_TECH_C
    __CONFIG(0x3fb1);
    #endif
    //Internal functions
    #include "C:\Program Files (x86)\Matrix Multimedia\Flowcode V4\FCD\internals.h"
    //Macro function declarations
    //Variable declarations
    char FCV_SWITCH;
    char FCV_ADC;
    //Defines:
    /**** Macro Substitutions ****
    0 = Which ADC Channel
    40 = Acquisition time
    3 = Conversion Speed
    0 = VRef+ Option
    500 = VRef Voltage x 0.01V
    //ADC0: //Macro function declarations
    void FCD_ADC0_SampleADC();
    char FCD_ADC0_ReadAsByte();
    short FCD_ADC0_ReadAsInt();
    float FCD_ADC0_ReadAsVoltage();
    void FCD_ADC0_ReadAsString(char* FCR_RETVAL, char FCR_RETVAL_SIZE);
    //Defines:
    porta = Switch Port Register
    trisa = Switch Data Direction Register
    1 = Switch Pin
    0 = Switch Polarity Control
    0 = Switch Debounce Delay Value
    //SWITCH0: //Macro function declarations
    char FCD_SWITCH0_ReadState();
    void FCD_SWITCH0_WaitUntilHigh();
    void FCD_SWITCH0_WaitUntilLow();
    //ADC0: //Macro implementations
    /*******Supported Devices******************************************************************
    // 16C72, 16C72A, 16CR72, 16F72, 16C73, 16C73A, 16C73B, 16F73, 16C74, 16C74A, 16C74B, 16F74,
    // 16C76, 16F76, 16C77, 16F77, 16F818, 16F819, 16F870, 16F871, 16F872, 16F873, 16F873A,
    // 16F874, 16F874A, 16F876, 16F876A, 16F877, 16F877A,
    #define MX_ADC_CHANNEL 0
    #define MX_ADC_SAMP_TIME 40
    #define MX_ADC_CONV_SP 3
    #define MX_ADC_VREF_OPT 0
    //set up ADC conversion
    char old_tris, cnt;
    //find appropriate bit
    #if (MX_ADC_CHANNEL == 0)
    #define MX_ADC_TRIS_MSK 0x01
    #define MX_ADC_TRIS_REG trisa
    #if (MX_ADC_VREF_OPT == 0)
    adcon1 = 0x0E;
    #else
    adcon1 = 0x05;
    #endif
    #endif
    #if (MX_ADC_CHANNEL == 1)
    #define MX_ADC_TRIS_MSK 0x02
    adcon1 = 0x04;
    #else
    adcon1 = 0x05;
    #endif
    #endif
    #if (MX_ADC_CHANNEL == 2)
    #define MX_ADC_TRIS_MSK 0x04
    adcon1 = 0x02;
    #else
    adcon1 = 0x03;
    #endif
    #endif
    #if (MX_ADC_CHANNEL == 3)
    #define MX_ADC_TRIS_MSK 0x08
    adcon1 = 0x04;
    #else
    #pragma error "Target device is currently using AN3 for VREF+"
    #endif
    #endif
    #if (MX_ADC_CHANNEL == 4)
    #define MX_ADC_TRIS_MSK 0x20
    adcon1 = 0x02;
    #else
    adcon1 = 0x03;
    #endif
    #endif
    #if (MX_ADC_CHANNEL == 5)
    #define MX_ADC_TRIS_REG trise
    adcon1 = 0x09;
    #else
    adcon1 = 0x01;
    #endif
    #endif
    #if (MX_ADC_CHANNEL == 6)
    adcon1 = 0x00;
    #else
    adcon1 = 0x01;
    #endif
    #endif
    #if (MX_ADC_CHANNEL == 7)
    adcon1 = 0x00;
    #else
    adcon1 = 0x01;
    #endif
    #endif
    //sanity check
    #ifndef MX_ADC_TRIS_REG
    #pragma error "ADC Type 1 conversion code error - please contact technical support"
    #endif
    //assign conversion speed
    #if (MX_ADC_CONV_SP > 3)
    st_bit(adcon1, ADCS2);
    #endif
    //store old tris value, and set the i/o pin as an input
    old_tris = MX_ADC_TRIS_REG;
    MX_ADC_TRIS_REG = MX_ADC_TRIS_REG | MX_ADC_TRIS_MSK;
    //turn ADC on
    adcon0 = (0x01 | (MX_ADC_CONV_SP << 6)) | (MX_ADC_CHANNEL << 3);
    //wait the acquisition time
    cnt = 0;
    while (cnt < MX_ADC_SAMP_TIME) cnt++;
    //begin conversion and wait until it has finished
    adcon0 = adcon0 | 0x04;
    while (adcon0 & 0x04);
    //restore old tris value, and reset adc registers
    MX_ADC_TRIS_REG = old_tris;
    adcon1 = 0x07;
    adcon0 = 0x00;
    #undef MX_ADC_CHANNEL
    #undef MX_ADC_TRIS_REG
    #undef MX_ADC_TRIS_MSK
    #undef MX_ADC_SAMP_TIME
    #undef MX_ADC_CONV_SP
    #undef MX_ADC_VREF_OPT
    return adresh;
    short iRetVal;
    iRetVal = (adresh << 2);
    iRetVal = iRetVal | (adresl >> 6);
    return (iRetVal);
    int iSample;
    float fSample, fVoltage, fVperDiv;
    #define MX_ADC_VREF_V 500
    iSample = FCD_ADC0_ReadAsInt(); //Read as 10-bit Integer
    #ifdef _BOOSTC
    fVoltage = float32_from_int32(MX_ADC_VREF_V); //Convert reference voltage count to floating point (0 - 500 x 10mV)
    fVoltage = float32_mul(fVoltage, 0.01); //Convert reference voltage count to actual voltage (0 - 5)
    fVperDiv = float32_mul(fVoltage, 0.000976); //Convert actual voltage to voltage per division (VRef / 1024)
    fSample = float32_from_int32(iSample); //Convert to floating point variable
    fVoltage = float32_mul(fSample, fVperDiv); //Calculate floating point voltage
    #endif
    #ifdef HI_TECH_C
    fVoltage = MX_ADC_VREF_V; //Convert reference voltage count to floating point (0 - 500 x 10mV)
    fVoltage = fVoltage * 0.01; //Convert reference voltage count to actual voltage (0 - 5)
    fVperDiv = fVoltage * 0.000976; //Convert actual voltage to voltage per division (VRef / 1024)
    fSample = iSample; //Convert to floating point variable
    fVoltage = fSample * fVperDiv; //Calculate floating point voltage
    #endif
    #undef MX_ADC_VREF_V
    return (fVoltage);
    float fVoltage;
    fVoltage = FCD_ADC0_ReadAsVoltage();
    FCI_FLOAT_TO_STRING(fVoltage, 2, FCR_RETVAL, FCR_RETVAL_SIZE); //Convert to String
    //SWITCH0: //Macro implementations
    char switchval;
    set_bit ( trisa, 1 ); //Convert pin to input
    delay_us(2); //Allow input voltage to settle
    if (test_bit( porta, 1 )) //Read state on input
    switchval = 1;
    else
    switchval = 0;
    if ( 0 == 1 ) //Active low polarity
    if (switchval) //Invert logic
    switchval = 0;
    else
    switchval = 1;
    return (switchval); //Return state of switch as least significant bit
    if ( 0 == 0 ) //Active high polarity
    while (test_bit( porta, 1 ) == 0); //Wait for pin to go high
    else //Active low polarity
    while (test_bit( porta, 1 )); //Wait for pin to go low
    if ( 0 ) //Timeout specified?
    Wdt_Delay_Ms(0);
    Wdt_Delay_Ms(0);
    void main()
    //Initialisation
    adcon1 = 0x07;
    //Interrupt initialisation code
    option_reg = 0xC0;
    //Loop
    //Loop: While 1
    while (1)
    //Call Component Macro
    //Call Component Macro: adc=ADC(0)::ReadAsByte
    FCV_ADC = FCD_ADC0_ReadAsByte();
    //Output
    //Output: adc -> PORT C
    trisc = 0x00;
    portc = FCV_ADC;
    //Call Component Macro: switch=SWITCH(0)::ReadState
    FCV_SWITCH = FCD_SWITCH0_ReadState();
    //Decision
    //Decision: switch = 1?
    if (FCV_SWITCH == 1)
    //Output
    //Output: 1 -> B0
    trisb = trisb & 0xfe;
    if (1)
    portb = (portb & 0xfe) | 0x01;
    else
    portb = portb & 0xfe;
    } else {
    //Output
    //Output: 0 -> B0
    if (0)
    else
    mainendloop: goto mainendloop;
    void MX_INTERRUPT_MACRO(void)
  11. victorment
    Jul 4, 2010
    52
    OK.Ill Try find the configuration bits. Thanks for all those who post.
