Pic Ethernet. Anyone could provide info?
Discussion in 'Embedded Systems and Microcontrollers' started by TCOP, Jan 16, 2015.
  1. TCOP
    Thread Starter Active Member
    Apr 27, 2011
    89
    Hello everyone,
    I am just trying to dig into the pic ethernet area. I have some very basic understanding of ENC28J60 ethernet controller and I've read AN833 (The Microchip TCP/IP Stack). I've downloaded the legacy MLA files from microchip (TCP/IP stack v5.42.08) and started trying a few things. I am using MPLAB 8.86 and Hitech C 18.
    Till now...only frustration.
    I really can't even compile the Demo App, I'm struglling to find the way out, hopefully today and I can't find any tutorial on the net regarding PIC ethernet. On the other hand, I can find a lot of material for arduino and this time, it is a little tempting to switch to AVR (please don't let me)
    My goal for now is just to blink a led through http.
    I really need some guidance so If anyone has experience on the PIC ethernet , please help me out.
  2. bzznxlad
    Dec 29, 2014
    10
  3. tshuck
    Oct 18, 2012
    3,531
    675
  4. TCOP
    Apr 27, 2011
    89
    I've been struggling all day to get the demo app to compile. I only get errors. Has anyone tried it before? Any help please will be welcomed
  5. tshuck
    Oct 18, 2012
    3,531
    675
    What errors are you getting? Those usually indicate what is wrong...
  6. TCOP
    Apr 27, 2011
    89
    No progress till now
    I've download TCPIP stack 2.2 and tried again. This is what I get:
    Executing: "C:\Program Files\HI-TECH Software\PICC-18\9.80\bin\mcc18.exe" -p=18F452 /i"C:\MCHPStack2.20" -I"C:\MCHPStack2.20\Source" "xeeprom.c" -fo="xeeprom.o" -D__DEBUG -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
    "C:\Program Files\HI-TECH Software\PICC-18\9.80\bin\picc18" --cmode=c18 -q --asmlist --pass1 -I. --chip=18F452 -IC:\MCHPStack2.20 -IC:\MCHPStack2.20\Source xeeprom.c -Oxeeprom.o -D__DEBUG
    xeeprom.c:
    51: #define StartI2C() SSPCON2_SEN=1
    ^ (111) redefining preprocessor macro "StartI2C" (C:\Program Files\HI-TECH Software\PICC-18\9.80\include\plib/i2c.h: 821) (warning)
    52: #define RestartI2C() SSPCON2_RSEN=1
    ^ (111) redefining preprocessor macro "RestartI2C" (C:\Program Files\HI-TECH Software\PICC-18\9.80\include\plib/i2c.h: 835) (warning)
    53: #define StopI2C() SSPCON2_PEN=1
    ^ (111) redefining preprocessor macro "StopI2C" (C:\Program Files\HI-TECH Software\PICC-18\9.80\include\plib/i2c.h: 807) (warning)
    54: #define NotAckI2C() SSPCON2_ACKDT=1, SSPCON2_ACKEN=1
    ^ (111) redefining preprocessor macro "NotAckI2C" (C:\Program Files\HI-TECH Software\PICC-18\9.80\include\plib/i2c.h: 850) (warning)
    78: #define MASTER 8 /* I2C Master mode */
    ^ (111) redefining preprocessor macro "MASTER" (C:\Program Files\HI-TECH Software\PICC-18\9.80\include\plib/i2c.h: 38) (warning)
    80: #define SLEW_OFF 0xC0 /* Slew rate disabled for 100kHz mode */
    ^ (111) redefining preprocessor macro "SLEW_OFF" (C:\Program Files\HI-TECH Software\PICC-18\9.80\include\plib/i2c.h: 44) (warning)
    81: #define SLEW_ON 0x00 /* Slew rate enabled for 400kHz mode */
    ^ (111) redefining preprocessor macro "SLEW_ON" (C:\Program Files\HI-TECH Software\PICC-18\9.80\include\plib/i2c.h: 45) (warning)
    83: SCK, SDO, SDI */
    ^ (111) redefining preprocessor macro "SSPENB" (C:\Program Files\HI-TECH Software\PICC-18\9.80\include\plib\spi.h: 63) (warning)
    xeeprom.c:
    56: static unsigned char ReadI2C( void );
    ^ (367) identifier is already extern; can't be static (warning)
    57: static unsigned char WriteI2C( unsigned char data_out );
    (367) identifier is already extern; can't be static ^ (warning)
    460: {
    480: {
    Executing: "C:\Program Files\HI-TECH Software\PICC-18\9.80\bin\mcc18.exe" -p=18F452 /i"C:\MCHPStack2.20" -I"C:\MCHPStack2.20\Source" "xlcd.c" -fo="xlcd.o" -D__DEBUG -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
    "C:\Program Files\HI-TECH Software\PICC-18\9.80\bin\picc18" --cmode=c18 -q --asmlist --pass1 -I. --chip=18F452 -IC:\MCHPStack2.20 -IC:\MCHPStack2.20\Source xlcd.c -Oxlcd.o -D__DEBUG
    Executing: "C:\Program Files\HI-TECH Software\PICC-18\9.80\bin\mcc18.exe" -p=18F452 /i"C:\MCHPStack2.20" -I"C:\MCHPStack2.20\Source" "arp.c" -fo="arp.o" -D__DEBUG -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
    "C:\Program Files\HI-TECH Software\PICC-18\9.80\bin\picc18" --cmode=c18 -q --asmlist --pass1 -I. --chip=18F452 -IC:\MCHPStack2.20 -IC:\MCHPStack2.20\Source arp.c -Oarp.o -D__DEBUG
    Executing: "C:\Program Files\HI-TECH Software\PICC-18\9.80\bin\mcc18.exe" -p=18F452 /i"C:\MCHPStack2.20" -I"C:\MCHPStack2.20\Source" "ARPTsk.c" -fo="ARPTsk.o" -D__DEBUG -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
    "C:\Program Files\HI-TECH Software\PICC-18\9.80\bin\picc18" --cmode=c18 -q --asmlist --pass1 -I. --chip=18F452 -IC:\MCHPStack2.20 -IC:\MCHPStack2.20\Source ARPTsk.c -OARPTsk.o -D__DEBUG
    Executing: "C:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe" /q /p18F452 "C18Cfg.asm" /l"C18Cfg.lst" /e"C18Cfg.err" /o"C18Cfg.o" /d__DEBUG=1
    Warning[230] C:\MCHPSTACK2.20\SOURCE\C18CFG.ASM 83 : __CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
    Warning[230] C:\MCHPSTACK2.20\SOURCE\C18CFG.ASM 84 : __CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
    Warning[230] C:\MCHPSTACK2.20\SOURCE\C18CFG.ASM 85 : __CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
    Warning[230] C:\MCHPSTACK2.20\SOURCE\C18CFG.ASM 86 : __CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
    Executing: "C:\Program Files\HI-TECH Software\PICC-18\9.80\bin\mcc18.exe" -p=18F452 /i"C:\MCHPStack2.20" -I"C:\MCHPStack2.20\Source" "delay.c" -fo="delay.o" -D__DEBUG -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
    "C:\Program Files\HI-TECH Software\PICC-18\9.80\bin\picc18" --cmode=c18 -q --asmlist --pass1 -I. --chip=18F452 -IC:\MCHPStack2.20 -IC:\MCHPStack2.20\Source delay.c -Odelay.o -D__DEBUG
    Executing: "C:\Program Files\HI-TECH Software\PICC-18\9.80\bin\mcc18.exe" -p=18F452 /i"C:\MCHPStack2.20" -I"C:\MCHPStack2.20\Source" "DemoSNMPAgent.c" -fo="DemoSNMPAgent.o" -D__DEBUG -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
    "C:\Program Files\HI-TECH Software\PICC-18\9.80\bin\picc18" --cmode=c18 -q --asmlist --pass1 -I. --chip=18F452 -IC:\MCHPStack2.20 -IC:\MCHPStack2.20\Source DemoSNMPAgent.c -ODemoSNMPAgent.o -D__DEBUG
    DemoSNMPAgent.c: main()
    295: XLCDGoto(1, 0);
    ^ (361) function declared implicit int (warning)
    296: XLCDPutROMString(SetupMsg);
    388: XLCDPut(myDHCPBindCount + '0');
    DemoSNMPAgent.c: SNMPSetVar()
    558: XLCDPutString(LCDDisplayString);
    DemoSNMPAgent.c: DisplayIPValue()
    715: itoa(IPVal->v[0], IPDigit);
    ^ (357) illegal conversion of integer to pointer (warning)
    ^ (358) illegal conversion of pointer to integer (warning)
    ^ (187) too few function arguments
    727: itoa(IPVal->v[1], IPDigit);
    739: itoa(IPVal->v[2], IPDigit);
    751: itoa(IPVal->v[3], IPDigit);
    DemoSNMPAgent.c: InitializeBoard()
    909: XLCDInit();
    DemoSNMPAgent.c:
    1048: "\r\nSerial Number (",
    ^ (359) illegal conversion between pointer types (warning)
    pointer to const char -> pointer to rom char
    1049: "\r\nDefault IP Address (",
    1050: "\r\nDefault Gateway Address (",
    1051: "\r\nDefault Subnet Mask (",
    1052: "\r\nDHCP & IP Gleaning enabled.\r\n",
    1053: "\r\nDHCP & IP Gleaning disabled.\r\n",
    1054: "\r\nReady to download MPFS image - Use Xmodem protocol.\r\n",
    (359) illegal conversion between pointer types ^ (warning)
    1056: };
    DemoSNMPAgent.c: ExecuteMenuChoice()
    1152: itoa(AppConfig.SerialNumber.Val, response);
    (187) too few function arguments ^
    (908) exit status = 1
    Halting build on first failure as requested.
    Debug build of project `C:\MCHPStack2.20\Source\DemoSNMPAgent.mcp' failed.
    Language tool versions: MPASMWIN.exe v5.46, mplink.exe v9.80, mcc18.exe v9.80, mplib.exe v9.80
    Preprocessor symbol `__DEBUG' is defined.
    Sat Jan 17 21:07:33 2015
    BUILD FAILED
  7. TCOP
    Apr 27, 2011
    89
    Grrrrrr.......
    After spending two days just trying to figure out the problem, guess what, I didn't....
    I managed to get things to work by downloading the TCP/IP Stack v4.02 and with language tool versions: MPASMWIN.exe v5.46, mplink.exe v4.45, mcc18.exe v3.44, mplib.exe v4.45, everything worked.
    I did nothing fancy this time. Just fixed the include paths and when I pressed ctr+F10, everything compiled properly.
    I don't know what to say....
    At least it works now!
  8. Brownout
    Jan 10, 2012
    2,375
    998
    Looks like the original problem was in the MCHPStack2.20. The code might have been OK. I've had a lot of difficulty not being able to compile perfectly good code on PIC compilers.
  9. TCOP
    Apr 27, 2011
    89
    Well, I just realized that if you plan to work with a small 16F or 18F then probably v2.2 is your only solution since it needs just about 12k of mem. Current version needs more than 60k so probably not a good choice more mid range mcus!
  10. TCOP
    Apr 27, 2011
    89
    @Brownout
    I am still missing a good tutorial about how to move further. Since you have already worked with TCPIP Stack, please enlighten me.
  11. Brownout
    Jan 10, 2012
    2,375
    998
    What kind of help do you need? So if I'm right, you have the stack compiled and running, and you just need some code, right? Ok well, I never wrote any code for your particular stack; however, I wrote a simple socket server for a Windows computer, and made a little blog entry for testing it. It won't run for you without some edits, at least you'll need a different #include directive. Anyway, here is the link. Let me know if this helps.
    http://www.electro-tech-online.com/blog-entries/simple-socket-server.190/
