PIC = Change LED Flash Rate With Pot
Discussion in 'Programmer's Corner' started by stringer85, Oct 21, 2009.
  1. stringer85
    Sep 25, 2008
    Alright Guys
    Please forgive me if this sounds trivial, I'm very new with PIC programing.
    Anyway I'm trying to find away to change the rate an LED flashes (NOT Brightness) using a pot input.
    Any Ideas?
    I'm guessing I would need some sort of ADC input for the pot to work.
    Then somehow update the delay loop variable with respect to the ADC Value.
    Im using a PICkit1 with the 16f684 PIC.
    I understand I could simply make this circuit using a 555 timer but I'm trying to do this digitally.
  2. Mike2545
    Mar 26, 2009
    116
    What language are you programming with ; C, ASM or Basic?
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Do you still have the source code that you installed with the PICkit 1?
    If so, have a look at default12.c and default12.h. They are in the \PICkit 1\DefaultDemonstration directory.
    Look at the isr near the bottom of default12.c.
    Remember, when you received the PICkit 1, it came with a 12F675 that was programmed to flash the 8 LEDs on the board; and you could change the rate of flash by changing RP1.
  4. stringer85
    Sep 25, 2008
    I'm (trying) programming in C. If you think it'll be easier to program in BASIC then I might have ago at that.
    SgtWookie I do have the code, but I can't find any called "default12.c"
    I checked the PICkit disc again and all it contains is a couple of tutorials and the code which correlates to the Evil Genius book.
    There's one called cPWM.c
    This piece of code reads the pot and turns on X amount of the 8 leds corresponding to the value of the pot input:
    #include <pic.h>
    /* cPWM - Display the PICkit Pot Input Value as an LED Brightness Level
    This program samples the voltage on RA0 using the ADC and Displays it using
    a PWM value on "P1D" (RC2). This Program is designed for the
    myke predko
    04.11.16
    __CONFIG(INTIO & WDTDIS & PWRTEN & MCLRDIS & UNPROTECT \
    & UNPROTECT & BORDIS & IESODIS & FCMDIS);
    int i, j, k;
    int ADCState = 0; // Keep Track of ADC Operation
    int ADCValue = 0;
    int Dlay = 63; // LED Time on Delay Variable
    const char PORTAValue[8] = {0b010000, 0b100000, 0b010000, 0b000100,
    0b100000, 0b000100, 0b000100, 0b000010};
    const char TRISAValue[8] = {0b001111, 0b001111, 0b101011, 0b101011,
    0b011011, 0b011011, 0b111001, 0b111001};
    const char NOTPORTA[8] = {0, 0, 0, 0, 0, 0, 0, 0};
    main()
    PORTA = 0;
    CMCON0 = 7; // Turn off Comparators
    ANSEL = 1; // Just RA0 is an Analog Input
    ADCON0 = 0b00000001; // Turn on the ADC
    // Bit 7 - Left Justified Sample
    // Bit 6 - Use VDD
    // Bit 4:2 - Channel 0
    // Bit 1 - Do not Start
    // Bit 0 - Turn on ADC
    ADCON1 = 0b00010000; // Selemct the Clock as Fosc/8
    PR2 = 0x0FF; // Work the Full Range
    T2CON = 0b00000100; // TMR2 On with No Prescaler
    CCP1CON = 0b01001100; // Enable PWM with P1D Active High
    PWM1CON = 0; // No Turn on/Off Delay
    TRISC2 = 0; // Make RC2/P1D Output Active
    CCPR1L = 0x080; // Start PWM at Intermediate Value
    k = 0;
    while(1 == 1) // Loop Forever
    for (i = 0; i < 8; i++ )
    { // Loop through Each of the 8 LEDS
    for (j = 0; j < Dlay; j++); // Display "On" Delay Loop
    if ((ADCValue & (1 << i)) == 0)
    PORTA = NOTPORTA;
    else
    PORTA = PORTAValue;
    TRISA = TRISAValue;
    } // rof
    switch (ADCState) // ADC State Machine
    case 0: // Finished, Start Next Sample
    GODONE = 1;
    ADCState++;
    break;
    case 1: // Wait for ADC to complete
    if (!GODONE)
    ADCState++; // Sample Finished
    break;
    case 2: // Save Sample Value in "ADCValue"
    ADCValue = ADRESH;
    ADCState = 0;
    break;
    } // hctiws
    k = (k + 1) % 10; // Update PWM Every 100 ms
    if (0 == k)
    CCPR1L = ADCValue; // Simply Change the PWM Value to Change the
    // LED Output
    } // elihw
    } // End cPWM
