pic c programming menu
Discussion in 'Programmer's Corner' started by summeranson, Feb 12, 2009.
  1. summeranson
    Feb 12, 2009
    28
    hi everyone..
    i am a uni undergrad, i am currently doing my final year project.
    but i am having problem in programing a c programming for my pic..
    my pic will be 16F877A from microchip.
    the problem is i don't really know what are the library i will be needing and also any setting i need as i need to connect it to RS232 and connect it to my pc and use it with kerboard control.
    any expert help will be much appreaciate..
    thanks everyone..
  2. mik3
    Feb 4, 2008
    4,846
    63
  3. summeranson
    Feb 12, 2009
    28
    thx mik3 it helps alot..
    i was looking 4 it quite a long time edi..
  4. mik3
    Feb 4, 2008
    4,846
    63
    I am happy this helps but note that not all the functions in the manual are valid for all PIC's. It depends on the PIC which functions are valid.
  5. AlexR
    Jan 16, 2008
    735
    54
    Also be aware that those library functions only apply to the CCS compiler, if you are using any other brand of C compiler then it will have its own (different) set of PIC library functions.
    The bottom line is read the manual that comes with your compiler.
  6. summeranson
    Feb 12, 2009
    28
    thanks every1 i m using ccs c compiler but the problem is there is too much pages haha..
    but well better than nothing..
    so i shall just read all of it..
    thx again..
