Dear People:
Thanks to all for sharing your knowledge. I was wondering if some of you have had a problem like the one I describe below. Any help will be welcomed!
Im dealing with integer unsigned binary division using a PIC. I implemented 24/24 bit division and everything went ok. But when performing 24/16 bit division, something goes wrong.
The dividend (numerator) is a 24 bit constant, but the divisor (denominator) is a variable number. When this denominator takes a low value (but still 16 bit value), say 10700 i.e., the error in the result is quite a lot, and it becomes bigger as the difference between both operands does too. Is there a solution to this?
Thanks again for your help. Greetings!
