PIC ADC - Current Limiting Resistor Req'd?
Discussion in 'Embedded Systems and Microcontrollers' started by elementalrage, Dec 15, 2009.
  1. elementalrage
    Thread Starter Active Member
    Jul 30, 2009
    59
    I'm just using a PIC to read a voltage divider will give readings between 0 and 5 volts. Do I need a current limiting resistor before it hits the ADC pin on my PIC?
  2. Dalaran
    Dec 3, 2009
    168
    What values are you using in your current divider? I never have used a current limiting resistor on the ADC inputs and have had no problems.
  3. elementalrage
    Jul 30, 2009
    59
    I have a 1k on the 5 volt side and a 20k potentiometer on the other. Ranging from ~500ohms to 20k.
    5v >> 1k ohm : ADC pin on PIC : 0~20k ohm >> 0 (GND)
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    To need a voltage divider, you must have a voltage to measure that exceeds the range of the ADC. As long as the divider does not load the input signal and distort it, it should work.
    What is the amplitude of your input?
  5. elementalrage
    Jul 30, 2009
    59
    I have voltages roughly between 1.7 and 5 volts.
  6. Markd77
    Sep 7, 2009
    2,803
    594
    There is no need to use a resistor if you are within the voltage specifications, in fact it could cause accuracy problems if you used a high value.
    From 12F629 datasheet:
