pic-2 usb burner compare against pickit2
Discussion in 'General Electronics Chat' started by Gold Dust, Jan 4, 2012.
  1. Gold Dust
    Feb 28, 2009
    5
    I am new to pic microcontrollers and have no experience with them.
    My question is does anybody have information on which of the following pic programmers are best for a newby. Talking Electronics "PIC-2 USB BURNER" or Microchip's "PICKIT2"?
    Also, which is easiest to learn.
    I plan on using basic language and a usb cable from pc to programmer.
    Any help or direction would be greatly appreciated.
    Thanks, Larry Gold
  2. t06afre
    May 11, 2009
    5,939
    1,222
    The "PIC-2 USB BURNER" is a PICKIT 2 clone so it should work as a PICKIT 2. However the "PIC-2 USB BURNER" is a kit you must assemble by your self. And parts has to purchased as I understand like the USB cable. So the cost may easy be close to PICKIT 2 in the end. If you are beginner just go for the PICKIT 2. It is plug and play. The "PIC-2 USB BURNER" is more of a plug and pray. If your budget allow it perhaps a PICKIT 3 is better
    Gold Dust likes this.
  3. t06afre
    May 11, 2009
    5,939
    1,222
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    I'd suggest a PICKit 2 direct from Microchip over ANYTHING ELSE, no matter how much you save.
    Most people get turned off uC programming because their programmer is junk, or a DIY kit that sometimes barely sorta works if you hold your tongue the right way.
    Starting off with a quality, affordable, assembled and tested programmer like the PICKit 2 will save both you and us (helping you) at least a week of frustration. :)
  5. nigelwright7557
    May 10, 2008
    488
    71
    I always go for Microchip kit, if they cant get it right then no one can !
    I have heard a few horror stories about copy parts that wont program certain PICs
  6. cravenhaven
    Member
    Nov 17, 2011
    34
    If you want to start with basic then perhaps it might be worth looking at the PICAXE chips. basically they are PIC chips preprogrammed with a built-in basic interpreter. No programmer hardware is required, the chips can be reprogrammed in circuit, the programmer and simulator tools are free and there is a fantastic web forum to help you earn it all.
  7. spinnaker
    Oct 29, 2009
    5,102
    1,190
    I would further that by suggesting a PicKit III. The II does not support a lot of the newer Pics. But if you can';t afford a III then get the II.
    But ThatOneGuy still has excellent advice, don't waste your time or money on a clone.
  8. thatoneguy
    Feb 19, 2009
    6,357
    718
    The PICKit 2 can program everything the PICKit 3 can, it just can't debug everything the PICKit 3 can, and those devices aren't in the mid-range familiy (PIC10-PIC18), mostly dsPIC and PIC32.
    The problem is that you have to manually download the device file to update the PICKIT 2 regularly, where the PICKit 3 is a bit more automated.
  9. CraigHB
    Member
    Aug 12, 2011
    127
    15
    I thought the PICkit3 was the one that had to update every time you use a different MCU. They broke out the the firmware into many parts to make the PICkit3 more versatile, or something.
    My PICkit2 has only needed an update a few times and there's no need to update for a particular device once you've got the latest update.
    If you look at the list of supported parts by going to Configure -> Select Device in MPLab, there's a lot of red dots (unsupported) in the "Programmers" section for the PICkit2. It' a lot of the newer devices in all the series. I'm expecting I'll have to buy a PICkit3 at some point. I read somewhere it's possible to do a hack to get the PICKit2 to program some officially unsupported devices. I have a feeling they're trying to obsolete the PICkit2 sooner than later for whatever reason. It's probably more political than technical.
    BTW, you can get the PICkit programmers stand-alone. They seem to push the development kits on the main Microchip web site. They're cheaper that way. The PICkit2 is $35 by itself and the PICkit3 is $45 by itself, still reasonable (here's a link). I've never felt compelled to buy any of the development boards. They kind of designed the PICkit for those boards, but it works great as a stand-alone programmer/debugger. Though it has the wrong gender on the connector because of that. I changed it on my PICkit2 and I'll probably change it on the PICkit3 when I get one.
  10. spinnaker
    Oct 29, 2009
    5,102
    1,190
    The updates aren't a big deal. It happens automatically in MPLab. It only takes a minute or two.
    Development boards are nice if you never programmed a Pic before. The one for the Pic Kit3 is really nice as it gives you lessons on the various features of the MCU.
  11. thatoneguy
    Feb 19, 2009
    6,357
    718
    I'll be using the PICKit 3 exclusively when they add the logic analyzer and UART debugger to the standalone program like they have on the PICKit 2. I don't see why they'd take a step backwards.
    Not everybody goes through MPLAB exclusively.
  12. spinnaker
    Oct 29, 2009
    5,102
    1,190
    That is a good question why they did not add the logic analyzer. Maybe they figured it was not being used much?
    What is the UART debugger? Is it basically a protocol analyzer or is it a debugger that works through a UART port?
  13. thatoneguy
    Feb 19, 2009
    6,357
    718
    It gives you a TTL Tranceiver at any baud rate. So you can talk to boards, etc without needing a separate USB->Serial FTDI adapter.
    debugger was in wrong place, it's also a PIC Debugger, but that's a different mode.
  14. spinnaker
    Oct 29, 2009
    5,102
    1,190
    So you mean like being able to send debug messages to the console? Yes that would be useful.
    Does it use the same connections for ICSP adapter?
  15. thatoneguy
    Feb 19, 2009
    6,357
    718
    Yes, it's physically exactly the same as the PICKit 3, button and LEDs in same place, same connector, etc.
    Both are used the same way to program/debug.
    They just didn't make those extra tools in the standalone programmer, I have both, and both standalone programs, but the standalone program for the 3 is program only, none of the extra features.
    The UART will let you talk to routers or send messages in a terminal window. You need to connect to Vdd, Gnd, Tx and Rx at logic level, not the 12V RS-232
    The UART, Logic Probe, and Logic Injector all "remap" the ICSP pins and when you open the tool, it shows a picture of how to connect it. It's worth the $35 just for those features!
