PIC 18F6620 don't work
Discussion in 'Embedded Systems and Microcontrollers' started by a21, Apr 7, 2010.
  1. a21
    Mar 24, 2010
    8
    I have a simple program for testing PIC 18F6620:
    void main()
    SET_TRIS_G(0x00);
    OUTPUT_HIGH(PIN_G3);
    while(1);
    It is done in CCS. I am using 20Mhz crystal with 16pF capacitors. The oscillator is set to HS. The problem is that the PIC is not working. G3 is low. I tried to insert NOP in 0x00, but this didn't help.
    EDIT: I checked OSC1 and OSC2 with oscilloscope and there is 80mV constant level.
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Have you set the configuration bits correct?
  3. a21
    Mar 24, 2010
    8
    Here is my .h file
    Code ( (Unknown Language)):
    1. #include <18F6620.h>
    2. #device adc=8
    3.
    4. #build (reset = 0x0002)
    5. #ROM 0 = {0x0000}
    6.
    7. #FUSES NOWDT                    //No Watch Dog Timer
    8. #FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
    9. #FUSES HS                       //High speed osc
    10. #FUSES NOPROTECT                //Code not protected from reading
    11. #FUSES NOOSCSEN                 //Oscillator switching is disabled, main oscillator is source
    12. #FUSES NOBROWNOUT               //No brownout reset
    13. #FUSES BORV25                   //Brownout reset at 2.5V
    14. #FUSES PUT                      //No Power Up Timer
    15. #FUSES NOCPD                    //No EE protection
    16. #FUSES STVREN                   //Stack full/underflow will cause reset
    17. #FUSES NODEBUG                  //No Debug mode for ICD
    18. #FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
    19. #FUSES NOWRT                    //Program memory not write protected
    20. #FUSES NOWRTD                   //Data EEPROM not write protected
    21. #FUSES NOCPB                    //No Boot Block code protection
    22. #FUSES NOEBTRB                  //Boot block not protected from table reads
    23. #FUSES NOEBTR                   //Memory not protected from table reads
    24. #FUSES NOWRTC                   //configuration not registers write protected
    25. #FUSES NOWRTB                   //Boot block not write protected
    26.
    27. #use delay(clock=20000000)
    28. #use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,stop=1)
    29.
  4. AlexR
    Jan 16, 2008
    735
    54
    The obvious question is do you have the MCLR pin pulled up to Vdd?
  5. a21
    Mar 24, 2010
    8
    Yes, I have pull up res to Vdd - 1K.
  6. a21
    Mar 24, 2010
    8
    I don't know does it matters, but PicKit2 shows me User Ids: FF FF FF FF FF FF FF FF
  7. t06afre
    May 11, 2009
    5,939
    1,222
    Then you program your device with a PICKIT 2, I am almost sure a verify is performed after the writing. If any error you will be warned. If you can perform a write cycle you can be pretty sure the MCU is OK. I would look for problems in the coding. And of course the hardware setup.
  8. a21
    Mar 24, 2010
    8
    I made new PCB and checked all connection, but it doesn't work. Here is my asm code (generated from CCS)
