Pic 18f4620, SPI programming
Discussion in 'Programmer's Corner' started by mcdara, Mar 10, 2011.
  1. mcdara
    Feb 23, 2011
    11
    Hey,
    Im working in this PIC and trying to get my MOSI pins working as I have this connected into MCP2515 chip acting as the Slave. (The moral of my question below is how to slow down the SPI data out MOSI pin)
    I have a code developed and I have a output of 5 volts on my CLK, on the oscilloscope I have the EXT Trigger connected to my chip select. But i am not getting a correct data reading from my data out pin, i have changed the binary number and it still give me the same distorted output, which is not interference so it is trying to give me something. I think maybe if i slow down the clock it will work, i can only slow down the whole PIC which is not what i want, anyone know how to slow down just the SPI mode data output?
    Il send some code to explain what I have
    Code ( (Unknown Language)):
    1.
    2. #include "p18f4620.h"
    3. #include "spi.h"
    4.
    5. #pragma config OSC = INTIO67  // Sets the oscillator mode to HS
    6. #pragma config WDT = OFF        // Turns the watchdog timer off
    7. #pragma config MCLRE = OFF        // Turns low voltage programming off
    8.
    9. void configure_pins(void);
    10. unsigned int read_analog_channel(unsigned int n);
    11.
    12. int Count;
    13. void main(void)
    14.
    15. initSPI();
    16.     Count  = 0;
    17.     while(1)
    18.     {
    19.     LATDbits.LATD1 = 1;
    20.         LATDbits.LATD0 = 0;
    21.
    22. void configure_pins()
    23.
    24.     TRISA = 0xFF;
    25.      ADCON1 = 0b00000111;
    26.
    27. LATD = 0;
    28.
    29. TRISD = 0b11110000;
    30.
    31. LATC = 0;
    32.
    33.     TRISC = 0b11110000;
    34.
    35. }
    36.
    37. unsigned int read_analog_channel(unsigned int n)
    38. {
    39.  // Set ADCON0 to specified channel, unset GO/NOTDONE bit, unset ADON bit
    40.  ADCON0 = n << 2;
    41.  // Select A/D acquisition time (NOT DONE YET - JUST DELAYING MANUALLY FOR NOW, SEE BELOW)
    42.  // Select A/D conversion clock (NOT DONE YET - JUST DELAYING MANUALLY FOR NOW, SEE BELOW)
    43.  // Turn on A/D module
    44.  ADCON0bits.ADON = 1;
    45.  // Manual wait acquisition time (should be more than enough)
    46.  for (n=0 ; n<100 ; ++n);
    47.  // Start conversion
    48.  ADCON0bits.GO = 1;
    49.  // Wait for conversion to finish
    50.  while (ADCON0bits.GO);
    51.  // Just return 8 MSBs of left justified sample from ADRESH:ADRESL
    52.  return ADRESH;
    53. }
    54.
    55.
