PIC 18 Ob-Board Programming
Discussion in 'Embedded Systems and Microcontrollers' started by nziebart, Feb 1, 2012.
  1. nziebart
    Feb 1, 2012
    I am a programmer and I'm working with a company to try to allow one of their machines to be controlled by an iPad. The machine has a circuit board with a PIC 18Fxxx microcontroller attached. Assuming that I can install a Wi-Fi module on the board, could I reprogram the microcontroller as it currently sits on the board?
    Sorry if this question is silly; I am not entirely familiar with the process for programming microcontrollers. The image below will hopefully clarify my explanation. It shows the controller seated on the board.
    EDIT: The board also has a "PRGM" input which I think might be what I'm looking for..
  2. t06afre
    May 11, 2009
    5,939
    1,222
    If the board is from the company you work for. Then it must someone who can give you a better answer than we can. All PICs with flash program memory. Have what is named ICSP (In Circuit Serial Programming) So only 5 wires will be needed. And of course a programmer unit. But without seeing a schematic for that unit. The best answer any here can give you is a maybe ;)
  3. ErnieM
    Apr 24, 2011
    7,439
    1,627
    The ICSP for a PIC uses 5 wires:
    VDD (+3 to +5V)
    VSS (ground)
    VPP (programming voltage)
    CLOCK
    DATA
    Find the data sheet for that exact PIC, and see if you can buzz out a connection from J11 to matching pins on the PIC. If so, you're found the on board programming adapter.
    If not, at least you know where to try tracing out.
