Pic 16HV610
Discussion in 'Programmer's Corner' started by Birdog, Dec 16, 2010.
  1. Birdog
    Dec 16, 2010
    Is there anyone who can help me program this PIC or give some code examples. I am trying to use a button for an input and turn on an output that blinks a # of seconds. I program PLC's and Drives but this language I am having a hard time understanding. I have MPlab and a pickit 2.:confused:
  2. R!f@@
    Apr 2, 2009
    8,791
    771
    Why don't you try googling or Microchip site itself
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
    Try Boost C or Boost BASIC for a language. Assembly on a PIC16 isn't the easiest thing in the world to pick up quick, but compilers make it easier if you know a language. Also popular for PIC16 are: MikroC and MikroBASIC, and PIC BASIC PRO.
    There are different pricing levels for all, but they all have a demo version that is RAM limited, but most applications do not come close to hitting the limitations until you are working with advanced projects.
  4. nerdegutta
    Dec 15, 2009
    2,567
    806
    Do you have a schematic?
    Need to see what is connected where to do the proper program.
    Try one of the above mentions languages. That's much easier than hard-core assembly.
    Perhaps he did that, but was not able to understand what it said? Maybe he want to chat with people? He should say what he has done so far....
  5. t06afre
    May 11, 2009
    5,939
    1,222
  6. jpanhalt
    Jan 18, 2008
    5,699
    909
    Just look up any of the 16F series. There are tons of examples for the 16F84; 16F84A; 16F628; and 16F628A.
    I started with Assembly and had no problem. If you know a flavor of C already, then that is probably where to start. But if you don't, Assembly from one of the many turorials is easy to pickup.
    John
  7. nigelwright7557
    May 10, 2008
    488
    71
    You need to set up an I/O port for your input and output then read and write to these accordingly.
    For a delay just make a code that loops and wastes time.
  8. psycho
    Dec 28, 2010
    1st post... Anyway, pick up a book called Programming and Customizing the PIC Microcontroller by Myke Predko. This is the book I used when I started with PICs. It not only goes through the hardware but also the software (in assembly language).
    Or, if you prefer, download a compiler (lots of example code available, too). They play very nicely with MPLAB! Check out:
    http://www.microchip.com/compilers/
    psycho
