1. Kanniyappan
    Oct 1, 2010
    8
    Hi i am having problem in programming my PIC16F877A
    here is the error message...
    I copied the data from my device and saved it as hex file that file burned successfully hence there is no problm in m yprogrammer hope so the message is ....
    "Checking connection of JDM Programmer ...
    Error opening LPT driver!
    JDM Programmer connected and initialized!
    Autodetecting PIC ...
    No PIC detected!
    Calibrating delay: 50us delay took 81us (loop counter=1362)
    PIC unknown! Programming may fail!!
    Configuration bits found in HEX file (config memory length = 16 bytes)!
    Erasing Device ...
    Erasing finished!
    Programming started ...
    Programming finished successfully!
    Operation took 38.0 seconds!
    But whn I use anyother hex file....it says there is error in verify
    "Configuration bits found in HEX file (config memory length = 16 bytes)!
    Verifing started ...
    Verify Error: Code Mem 0x000000: PIC=0x3FFF Buf=0x2804
    Verify Error: Code Mem 0x000008: PIC=0x3FFF Buf=0x1303
    Verify Error: Code Mem 0x00000A: PIC=0x3FFF Buf=0x1683
    Verify Error: Code Mem 0x00000C: PIC=0x3FFF Buf=0x0186
    Verify Error: Code Mem 0x00000E: PIC=0x3FFF Buf=0x30FF
    Verify Error: Code Mem 0x000010: PIC=0x3FFF Buf=0x1283
    Verify Error: Code Mem 0x000012: PIC=0x3FFF Buf=0x0086
    Verify Error: Code Mem 0x000014: PIC=0x3FFF Buf=0x3006
    Verify Error: Code Mem 0x000016: PIC=0x3FFF Buf=0x00FC
    Verify Error: Code Mem 0x000018: PIC=0x3FFF Buf=0x30FF
    Verify Error: Too much errors in Code Mem, giving up!
    Verify Error: Data Mem 0x000000: PIC=0x00FF Buf=0x00C0
    Verify Error: Data Mem 0x000001: PIC=0x00FF Buf=0x00A8
    Verify Error: Data Mem 0x000002: PIC=0x00FF Buf=0x0000
    Verify Error: Data Mem 0x000003: PIC=0x00FF Buf=0x0064
    Verify Error: Data Mem 0x000004: PIC=0x00FF Buf=0x0000
    Verify Error: Data Mem 0x000005: PIC=0x00FF Buf=0x0000
    Verify Error: Data Mem 0x000006: PIC=0x00FF Buf=0x0000
    Verify Error: Data Mem 0x000007: PIC=0x00FF Buf=0x0000
    Verify Error: Data Mem 0x000008: PIC=0x00FF Buf=0x0000
    Verify Error: Data Mem 0x000009: PIC=0x00FF Buf=0x0000
    Verify Error: Too much errors in Data Mem, giving up!
    Verify Error: Cfg Mem 0x00000E: PIC=0x3FFF Buf=0x3F7A
    Operation took 5.0 seconds!"
    what can i do now...
    can anyone help me...
    here i attached both of my hex files...
    16f877a.hex the hex file read from device
    led.hex my hex file for blinking led...
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Are you sure your PIC is supported by your programing software? Have you tested your JDM programmer on other PICs.
  3. Kanniyappan
    Oct 1, 2010
    8
    no I didn't...I am newbie to microcontrollers and i have posted the message shown by the programmer... LED in my programmer blinks well nice...
  4. BillO
    Distinguished Member
    Nov 24, 2008
    985
    136
    A JDM programmer is normally a serial device. Why is your software trying to open the printer port? Do you have the correct port defined for your programmer?
    One more thing, what software are you using?
  5. Zahir_s
    Member
    Dec 23, 2014
    32
    @Kanniyappan - I have the same problem, how did you solve it?
  6. Art
    Sep 10, 2007
    797
    61
    Nowadays most serial ports don't comply with RS232 and don't supply enough voltage for programming mode. If you can't afgord a pickit programmer, I would try getting hold of an old PC with proper serial port.
  7. MagicMatt
    Member
    Sep 30, 2013
    117
    14
    Your hex files burnt to a PIC16F877A happily using a PICKit2 on my computer, so your hex file should be fine.
    That means the problem is either your programmer, your PIC chip, or your driver/computer hardware.
    Serial ports usually use COM drivers, not LPT drivers... so that's a strange message. Are you using something that gives you a serial port via your parallel port? If so, don't, because they generally don't work. In fact, I've only ever see them work with things like serial plotters/cutters that are designed to be able to connect this way.
    If you are using a USB to Serial Port cable, this also probably wont work - the specification is different enough that some hardware that requires specific voltages wont work.
    Most laptop serial ports also don't provide enough voltage on their own (they work with devices that have their own power supplies, but often not with devices that draw power from the serial port, regardless of the device). You might be able to modify the programmer to leech some extra voltage from a spare USB port, but you would do better to use a computer that has a full-strength serial port.
  8. Zahir_s
    Member
    Dec 23, 2014
    32
    I have a proper desktop with a db-9 COM1, connected to the schematic using a male-female cable but there is one thing though, I'm prototyping the JDM on a breadboard using the attached scheme. I have connected the circuit and lead out the required wires to the MCU(16f877a) directly (w/o using a ZIF). on the PC I use the latest version of PICPgm software.
    Now so far I have been able to make the PICPgm autodetect the JDM.
    But when I try to detect the MCU it fails, says 'No PIC Detected' ,
    then when I don't use autodetect, and select the PIC ie 16f877a , it shows '**PIC Unkown**'
    then when I try to program it anyway it comes out with Verify Errors in the Code Memory and the Log is filled with this:
    -LOG(PICPgm)-
    CalibrateDelay_us: 100000000 loops took 125ms
    CalibrateDelay_us: loop counter for 1us = 1040
    Testing delay: 100us delay took 142us (loop counter = 1040)
    Erasing Device ...
    Erasing finished!
    Verify Error: Code Mem 0x000000: PIC=0x3FFF Buf=0x2820
    Verify Error: Code Mem 0x000002: PIC=0x3FFF Buf=0x3400
    Verify Error: Code Mem 0x000004: PIC=0x3FFF Buf=0x3400
    Verify Error: Code Mem 0x000040: PIC=0x3FFF Buf=0x1683
    Verify Error: Code Mem 0x000042: PIC=0x3FFF Buf=0x1303
    Verify Error: Code Mem 0x000044: PIC=0x3FFF Buf=0x0188
    Verify Error: Code Mem 0x000046: PIC=0x3FFF Buf=0x1283
    Verify Error: Code Mem 0x000048: PIC=0x3FFF Buf=0x0188
    Verify Error: Code Mem 0x00004A: PIC=0x3FFF Buf=0x30FF
    Verify Error: Code Mem 0x00004C: PIC=0x3FFF Buf=0x0088
    Programming finished with verify errors!
    Operation took 30.0 seconds!
    Now I'm inquisitive as to why is a 100us delay taking 27 to 42 us longer and what part of the circuit is it related to?
    I'm pretty sure if the delay calibration comes out right everything else will fall into place.
    Any other ideas? everyone is welcome
    and thank you for listening me out
  9. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    If the adapter is something you are wiring up be sure that your male-female DB9 hookups haven't introduced a null-modem (or maybe it needs one and you don't have one). Is pin 5 really Vdd? Its normally GND. That would mean some fancy use of the RS232 levels on the other pins (which is possible) or its backwards. I'm guessing its OK based on the other pins but check it out. When idle, measure the voltage on the PIC pins (Vdd/Vss, logic levels on PGC,PGD etc.
    Your first error PIC unknown! Programming may fail!! indicates that its not communicating with the PIC or that the PIC is not properly powered - that's why auto-detect fails, too.
    I don't know where the reported discrepancy in the 100us timer comes from but it sounds like it may be related to attempts to calibrate and do software delays by counting on a PC - problematic at best. Make sure no other programs are running then go to ControlPanel-Power Settings and set it to full power-full speed all the time (no backing off on CPU freq when there's nothing to do) to keep the system speed constant.
    Good luck!
  10. MagicMatt
    Member
    Sep 30, 2013
    117
    14
    At the risk of over-simplifying, that sounds more like the serial cable itself is faulty. Any chance you can put the thing direct on the port and eliminate that possibility?
  11. Zahir_s
    Member
    Dec 23, 2014
    32
    @MagicMatt No, can't do that, I'm using a breadboard, but I think the cable is fine the issue is with something else.
    I'm getting a 4.9V reading between the Vdd and Vss pins of the PIC, is that appropriate or is there a voltage drop that we don't need down the line?
    Better still, I'll give you guys a list of voltage levels I'm getting at the PIC pins.
    All measured with reference to the Vss pin's voltage, which is grounded
    Vpp - 16.54
    Vdd - 4.97
    PGC(Clock) - 3.35
    PGD(Data) - 5.61
  12. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    According to the 16F877A Programming Spec Vpp should be 13.5V max. Yours is high. Also, the program mode is entered by raising MCLR to VPP while holding PGC/PGD at logic lows and a low is the quiescent state - at least for PGC. Yours are both at logic high levels. You should also check that no input exceeds Vdd when MCLR is not at Vpp.
    I would carefully check the circuit to get things back into spec. The PIC may be blown due to the excessive Vpp but maybe not - they are pretty tough. Get the levels right and see what it does.
    Good Luck.
  13. MagicMatt
    Member
    Sep 30, 2013
    117
    14
    Ummm... I don't think that's going to work! As John says... it's a bit high!
  14. Zahir_s
    Member
    Dec 23, 2014
    32
    I have managed to get Vpp down to 13.6 is is alright or should I get it somewhere between 13.0 to 13.5? The Vdd, PGC and PGD levels are spot on according to specs.
  15. Zahir_s
    Member
    Dec 23, 2014
    32
    Hi guys.
    I've got the Vpp voltage down to the specs, now the led for PGC won't glow at all during operation, when testing it glows correct but during PIC detection, it doesn't.
  16. MagicMatt
    Member
    Sep 30, 2013
    117
    14
    If the spec says 13V +/- 0.5V, then you should stick to what the spec says, and be providing 13V within that tolerance. The spec is generally there for a reason- things don't work if you go outside them, or worse, things get damaged.
    Bearing in mind you were putting 16.54V into a chip designed to take 13V, which is well outside the spec, I wouldn't like to say whether or not that chip is still ok or has been damaged. Personally I think you've probably fried it.
  17. ErnieM
    Apr 24, 2011
    7,443
    1,628
    I wouldn't be so fast to toss the PIC out. AFAIK the Vpp voltage is not actually used to drive anything as it was back in the days of EEPROM, instead it just flips a comparator output to enable the function.
    It's worth a shot to retest the PIC.
    The programmer is shot. If you have the funds do get a PICkit 3 from Microchip. Clones are just not worth the hassle.
  18. Zahir_s
    Member
    Dec 23, 2014
    32
    Well I could just buy a programmer off the market but a friend of mine did this as a 3rd year project and I was hoping to replicate it.
    Anyway I'm sure I'm not following the schematic properly enough. So I don't mind the hassle cause I want to do this.
    Thanks for your inputs good people. And a Happy New Year!! (late, I know)
  19. MagicMatt
    Member
    Sep 30, 2013
    117
    14
    There are some things worth making, and some that are too much hassle. I didn't make my own programmer for the same reason I didn't make my own multimeter - I needed to know they worked properly from the start. Sure, I may make both myself for interest at some point, but they are tools, so well worth the spend.
    ErnieM likes this.
  20. Zahir_s
    Member
    Dec 23, 2014
    32
    @everyone
    I got it working with no verify errors, I was absolutely foolish when I over looked the role played by the current limiting resistors attached to the LEDs, turns out un-limited LEDs were draining all the current to the ground and thus messing with the proper voltage levels in the circuit.
    Thank you guys for your ears, advice and support.
    ErnieM likes this.
