I have a pic 16f877a I notice that when i pull the reset pin low to reset the pic starts to transmit a constant stream of 0x00 . The pic is connected to a max232 to handle the level conversion to pc serial port. The program I am running on the chip works fine but this transmitting a stream of null chars is causing the bootloader program not to work. Two different chips do this so i dont know is this the standard behavious for pic chips in reset ?
