PIC 16F877A programming
Discussion in 'Embedded Systems and Microcontrollers' started by nairsivan, Jul 29, 2011.
  1. nairsivan
    Jul 29, 2011
    i am doing a project which uses PIC 16F877A.There is an array of 16 detectors(2 rows 8 each).the outputs from these detectors are converted into digital values by using comparators.This digital output should be stored in pic and finally shud be given to PC for some processing SO THT I CAN READ THIS ARRAY using matlab.i dont know how to write progam for pic.
    hardware used: detector-comparator-pic-max 232-PC
    can anyone help me to do this
  2. guitarguy12387
    Apr 10, 2008
    359
    12
    Welcome to the forums!
    Sounds to me like you need a UART transmitter. Try google for that. There will be TONS to get you going.
    Beyond that, we can help you with specific questions... but we can't help so much with designing your project for you.
