Ok about 5 years ago a company came to me with some code to work on, they couldn't find anyone to work on it at all. They tried to fly people in etc... but no luck, lots of talk, very little production. The code was originally written by a IT class and professor as a class project. Runs right about 5000 lines of code. 5 years ago I taught myself the basics and actually managed to make all the changes they wanted. Yea! Me! >>>>TimeWarp 5 years>>>>. Same people contact me about makeing new code for a new device they are working on. All the previous programmers that took the job took the deposit and ran. Can't really blame em because the people I work for are the kind of people who think they know what their doing but don't which makes htem twice as dangerous. Well I accepted the job on salary and the got the assembly code for the old device they need some work on. I try to build the asm and I get all these errors. I comb the code and some idiot was trying to mix C with ASM without declaring anything or that he's gonna write some C code. I filtered that out and it removed all the errors I was having. Now I've got about 200 warning messages saying Operand in not in Bank0 check config bits. Were using the BankSet1 command but its not being recognized anymore.
Heres some code from the BankSet commands.
Rich (BB code):__CONFIG _WDT_OFF & _BODEN_OFF & _PWRTE_ON & _XT_OSC & _LVP_OFF & _DEBUG_OFF & _CPD_OFF
Include File
SourceRich (BB code):;Register PORTA EQU H'0005' PORTB EQU H'0006' ;Status Bits RP1 EQU H'0006' RP0 EQU H'0005' ;Config Bits _CP_ALL EQU H'1FFF' _CP_OFF EQU H'3FFF' _DEBUG_OFF EQU H'3FFF' _DEBUG_ON EQU H'37FF' _WRT_OFF EQU H'3FFF' ; No prog memmory write protection _WRT_256 EQU H'3DFF' ; First 256 prog memmory write protected _WRT_1FOURTH EQU H'3BFF' ; First quarter prog memmory write protected _WRT_HALF EQU H'39FF' ; First half memmory write protected _CPD_OFF EQU H'3FFF' _CPD_ON EQU H'3EFF' _LVP_ON EQU H'3FFF' _LVP_OFF EQU H'3F7F' _BODEN_ON EQU H'3FFF' _BODEN_OFF EQU H'3FBF' _PWRTE_OFF EQU H'3FFF' _PWRTE_ON EQU H'3FF7' _WDT_ON EQU H'3FFF' _WDT_OFF EQU H'3FFB' _RC_OSC EQU H'3FFF' _HS_OSC EQU H'3FFE' _XT_OSC EQU H'3FFD' _LP_OSC EQU H'3FFC'
Now the code used to run perfectly with no errors or messages. Now everytime BankSet1 is called. The following commands send messages saying operand not in Bank0. Then it goes back to BankSet0 and no more messages. Then call BankSet1 and the lines after it all give the Bank0 message. Any idea whats causing this? It also won't program anymore. I tried hooking my pk3 up to it pin for pin and it won't detect it. Any ideas?Rich (BB code):#define BankSet0 bcf STATUS,RP0 ; Set the RAM bank to 0 #define BankSet1 bsf STATUS,RP0 ; Set the RAM bank to 1 ; Bank-Select Names (for use with BANKSEL directive) BANK0 EQU PIR1 BANK1 EQU PIE1 BANK2 EQU EEDATA BANK3 EQU EECON1
hello every body,
I need help on my line follower robot based on PIC 16f877A. i download C source code and try to compile this code in MPLAB. but it show missing error in first 6 line. but i can't find any problem those line. i give the code without header file. plz any body find the error or convert it HEX format.
#include <16F877A.H>; //declare a PIC header
#device adc=8; //set the bit for ADC
#fuses hs, nowdt, noprotect; //set the PIC protection
#use delay (clock=20000000); //set the clock frequency
#byte porta=5; //assign port a
#byte portd=8; //assign port d
int val1; //ADC value 1 left sensor
int val2; //ADC value 2 center sensor
int val3; //ADC value 3 right sensor
int vref; //voltage reference
void lmotor(int gear); //left motor function
void rmotor(int gear); //right motor function
void main() //main function
vref=0x7f; //set voltage reference value
set_tris_d(0); //declare port d as output
setup_port_a(all_analog); //enable port a as ADC port
setup_adc(adc_clock_internal); //set the clock for ADC
setup_ccp1(ccp_pwm); //set enable ccp1
setup_ccp2(ccp_pwm); //set enable ccp2
setup_timer_2(t2_div_by_4,100,1); //set post scaler timer
while(1) //inifinite loop
portd=0xaa; //set value for motor
set_adc_channel(0); //ADC at port A0 channel
val1=read_adc(); //read and store A0 value
set_adc_channel(2); //ADC at port A2 channel
val2=read_adc(); //read and store A2 value
set_adc_channel(4); //Adc at port A4
val3=read_adc(); //read and store A4 value
//start condition
//if sensor sense dark then value is greater than Vref
//if sensor sense bright then value is lower than Vref
if(val2>vref) //if sensor 2 is dark
if((val1<vref)&&(val3<vref)) //sensor 1&3 is bright
{ //send value to motor ccp
lmotor(70); //both motor moving at same rate
rmotor(70);
else if (val1>vref) //sensor 1 is dark
lmotor(0); //left motor stop
rmotor(70); //right motor move
else if (val3>vref) //sensor 3 is dark
lmotor(70); //left motor move
rmotor(0); //right motor stop
else if ((val1>vref)&&(val3<vref)) //if only sensor 1 is dark
else if ((val3>vref)&&(val1<vref)) //if only sensor 3 is dark
else //other than condition above
lmotor(60); //left motor move slow
rmotor(60); //right motor move slow
//end program
void lmotor(int gear) //left motor ccp control function
set_pwm1_duty(gear); //ccp1 duty cycle
void rmotor(int gear) //right motor ccp control function
set_pwm2_duty(gear); //ccp2 duty cycle
It is very very emargency in my study.
Plz help me very queckly.
Thanks to all
Mehedi.
