Guys,
I am fairly new to Hardware design and PIC programming currently working on PIC 16F877A. I have initialized PORTA and PORTB in input mode and PORTC and PORTE in output mode. Based on logic present the input port, I am setting logic on output port. In idle condition output ports remain zero. But sometimes it jumps to logic 1 and then back to zero. This behavior is pretty random and I am not able to understand the problem. Do you have any suggestion or possibilities I can try to stop this unwanted oscillation?
I am using simple while loop to run the operation and if/else statements to compare input port logic. I am sure that MCLR pin is set to high while running this operation.
any help is appreciated... Thanks in advance
MAK
MAK
