pic 16f877a help required
Discussion in 'The Projects Forum' started by supahariz, Apr 24, 2011.
  1. supahariz
    Sep 8, 2010
    15
    hello all,
    i am new to pic and I'm having problems with a project i'm doing now.
    i have used a pic 16f877a to control 8 dc motors using 4 l293b h-bridge ic.
    i have used port a with port e (pin e0, pin e0) as input 1 for the h-bridge, port b pins as input 2 for the h-bridge, port d pins as enable inputs.
    i have used a 20Mhz oscillator with 33pf capacitors.
    my problem is, i am not getting the required voltage on any of the output pins.
    i need to get 5 volts on all the ports specified.
    but i am getting only 1.02v max.
    i am using ccs or pcw *pic c compiler v 4.023*
    please help me with this...
    i have attached .c and .h files as well
    thank you!
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    I do not see any attached files.
    Can you also post the schematic, how the pic and l293's are connected?
    Bertus
  3. supahariz
    Sep 8, 2010
    15
    here are the .c and header files.
    please help.
  4. supahariz
    Sep 8, 2010
    15
    i have added the attachments,
    the schematic will be up shortly.
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Firts I am not very good in programming, but I see this many times in the c file:
    Code ( (Unknown Language)):
    1.  for(i=0; i<500; i++)
    2.    {
    3.    output_high(PIN_A1);
    4.    output_low(PIN_A1);
    5.    }
    6.
    Af far as I understand the pin is set high and immediately low again.
    There is no delay in between, so there will be "needle" pulses at the output.
    Bertus
  6. supahariz
    Sep 8, 2010
    15
    here is the schematic for the same...
  7. supahariz
    Sep 8, 2010
    15
    sorry!! my bad,
    here is the correct schematic!!
      File size:
      150.3 KB
      26
  8. blacknewnew
    Aug 19, 2010
    Agree, and i think before that, the related pins should be configured as OUTPUT
  9. supahariz
    Sep 8, 2010
    15
    okay, i changed the code, and still the problem persists!
    please have a look at the code..
    and yeah i have pre configured the outputs..
  10. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Do you have any idea how long your for-loop will take?
    Does the compiler support delay commands?
    Then you can use those to create the delays between the pulses.
    BTW are you actualy building the circuit or are you simulating?
    If you are actualy building the circuit a logic probe will show you if the pulses are coming at the outputs.
    (it does not tell you how long the pulses are).
    Here I made a simple TTL logic probe:
    Project: TTL Logic probe.
    Bertus
  11. blacknewnew
    Aug 19, 2010
    Some compilers would change the code from
    for(i=0; i<50; i++)
    output_low(PIN_A1);
    like to
    output_low(PIN_A1);
    if compilation optimization is turned ON, please check it(and there may be better ways to do the delay).
    if it still does not work, you can try to execute a very simple code first and measure the IO voltage, to make sure it works as you expected, like:
    void main()
    //Add your port init code here
    output_high(PIN_A1); //A1 should stay high
    output_low(PIN_A0); //A0 should stay low
    while(TRUE);
