Hi all,
I am trying to make a frequency counter and wrote some code. I wanted to use a frequency averaging part to make things more accurate. But when I run the code with the averaging part it acts funny (at frequencies close to 10kHz).
Also please give me some pointers to the variable declaration (eg int, float etc) as I am pretty sure me using "int" is wrong. Furthermore the way I am doing the calculations, is there a better/faster way of doing them.
I'm using a PIC16F877A with 4MHz crystal.
Regards
Regards
Rich (BB code):
Rich (BB code):
sbit LCD_RS at RB2_bit;
sbit LCD_EN at RB3_bit;
sbit LCD_D4 at RB4_bit;
sbit LCD_D5 at RB5_bit;
sbit LCD_D6 at RB6_bit;
sbit LCD_D7 at RB7_bit;
sbit LCD_RS_Direction at TRISB2_bit;
sbit LCD_EN_Direction at TRISB3_bit;
sbit LCD_D4_Direction at TRISB4_bit;
sbit LCD_D5_Direction at TRISB5_bit;
sbit LCD_D6_Direction at TRISB6_bit;
sbit LCD_D7_Direction at TRISB7_bit;
int kk = 0;
int fr = 0;
int cnt = 0;
int rit = 0;
int acc = 0;
int i = 0;
int fra[10];
char CN[10];
void interrupt() {
if(INTCON.TMR0IF == 1){
fr = (cnt + kk*256)*(1000000)/(256*256); //4MHz crystal, 256 Timer0 increment rate
/*if(acc<10){ ///
fra[acc] = fr; ///Counted frequencies are put into an array
acc++; ///
else if(acc >= 10){
acc = 0;
for(i=0;i<10;++i){ ///
rit = rit + fra; ///Average frequency is calculated
rit = rit/10; ///
cnt = 0;
kk = 0;
INTCON.TMR0IF=0;
if(INTCON.INTF == 1){
cnt++;
if(cnt>=256){
cnt = 0;
kk++;
INTCON.INTF = 0;
void main() {
Lcd_Init();
Lcd_Cmd(_LCD_CLEAR);
Lcd_Cmd(_LCD_CURSOR_OFF);
PWM1_Init(1000);
PWM1_Set_Duty(100);
PWM1_Start();
INTCON.GIE = 1; //Enable Global Interrupt
INTCON.INTE = 1; //Enable RB0/INT external Interrupt
INTCON.TMR0IE = 1; //Enable TMR0 Overflow Interrupt
OPTION_REG.T0CS = 0; //Timer0 increments with Internal instruction cycle clock
OPTION_REG.PSA = 0; //Prescaler is assigned to the Timer0 module
OPTION_REG.PS2 = 1; ////
OPTION_REG.PS1 = 1; ////Timer0 increments every 256 instruction cycles
OPTION_REG.PS0 = 1; ////
OPTION_REG.INTEDG = 1; //Interrupt on rising edge
while(1){
IntToStr(fr,CN);
Lcd_Out(1,1,CN); //Display the average frequency
