PIC 16F877 assembly code
Discussion in 'Embedded Systems and Microcontrollers' started by chilly, Sep 16, 2008.
  1. chilly
    Sep 16, 2008
    7
    I'm working with a PIC 16F877
    My PIC program is reading input from portA then show output in portB
    My problem is when portA is 10001 then it will make RB0=1, when portA is 10011 it will make RB1=1
    but when portA is 10011 is will make both RB0, RB1=1
    How can I solve this problem? I want when portA is 10011 is make RB1=1 only
    Thanks for any suggestion.
  2. n9352527
    Oct 14, 2005
    1,198
    Check for both cases then, truth table will give you clearer idea on how to implement the program.
    Code ( (Unknown Language)):
    1.
    2. 00 -> 00
    3. 01 -> 01
    4. 10 -> 10
    5. 11 -> 10
  3. chilly
    Sep 16, 2008
    7
    Could you explain clearer? Note that I'm using assembly language to program the PIC
    Thnaks.
  4. n9352527
    Oct 14, 2005
    1,198
    You need to handle all the cases in the truth table above. In pseudocode, the first entry in truth table will translate to something like:
    if RA0 is 0 and RA1 is 0, set RB0 to 0 and RB1 to 0
    You have to do all entries, and then write the corresponding assembly program.
  5. geko
    Sep 18, 2008
    9
    Something like this should work
    1.
    2. RB0 equ 0
    3. RB1 equ 1
    4.
    5.               clrf          copyPORTB
    6.               movfw         PORTA
    7.               sublw         b'00010001'
    8.               skpnz
    9.               bsf           copyPORTB,RB0
    10.               sublw         b'11111110'
    11.               skpnz
    12.               bsf           copyPORTB,RB1
    13.               movfw         copyPORTB
    14.               movwf         PORTB
    15.
  6. chilly
    Sep 16, 2008
    7
    Thanks for your supports. I got the solution already.
  7. Prasanna K Routray
    Sep 17, 2015
    8
    @ Chilly how? will you please let me know?
  8. dannyf
    Sep 13, 2015
    2,196
    417
    What exactly do you want to happen when PORTA is 10011?
  9. dannyf
    Sep 13, 2015
    2,196
    417
    Couldn't have been simpler:
    Code (Text):
    1.
    2.   switch (PORTA) {
    3.     case 0b10001: set/clear RB0/1; break;
    4.     case 0b10011: set/clear RB0/1; break;
    5.   }
    6.
  10. absf
    Dec 29, 2010
    1,493
    374
    See the thread here.
    This thread is 7 years old. The mod will be coming to close it.
    Allen
