Hello members,
I am working on PIC 16f684 which uses interrupt on change. On receiving interrupt on port A, I am resetting a particular port pin,which is otherwise logic high. This logic works fine with through hole components, but the same logic does not work when the circuit is implemented in SMD. I even added ESD (electrostatic discharge) protection to no avail. ESD includes two zener diodes connected back to back between Vss & Vdd and the output given to interrupt on change pin.
Some discussion on this will be great help.
Thank-you.
Thank-you.
