Hi all,
I am trying to knock together a 'knight-rider' display using software PWM of 9 L.E.D.s using outputs from a PIC16F676 (all outputs have a 680 ohm resister on them in series with L.E.D.).
I am just using MPLAB to software simulate and programming using an Embedinc programmer (ISCP connection).
The .asm code works perfectly when I software simulate it on a PC. Ports RA4 and RA5 are enabled appropriately.
In practice the circuit works great but outputs RA4 and RA5 don't do anything (i.e. stay at ground potential). I have the IC set to use the internal clock and to not output the clock (which would come out on RA4 or RA5 I believe). Even if I hard code a port RA4 and RA5 enable in the code ... still no joy so I guess it's something to do with the shared nature of the outputs (perhaps ??)
The comparator is turned off, all port A as digital outputs (ANSEL and TRISA both cleared) - obviously I don't use RA3.
Any suggestions what I could be doing wrong?? My configuration code is in the box below...
Any help would be appreciated!! (From a complete newbie!!)
Rob
Rob
Rich (BB code):
ORG 0
GOTO RESET
ORG 4
INTERRUPT
RESET
CLRWDT
BSF STATUS,RP0 ; Bank 1
CLRF WPUA
CLRF IOCA
MOVLW B'10000111'
MOVWF OPTION_REG
MOVLW B'00010000'
MOVWF ADCON1
MOVLW B'00000000'
MOVWF ANSEL
MOVLW B'00000000'
MOVWF TRISA
MOVLW B'00000000'
MOVWF TRISC
BSF PIE1,TMR1IE
BCF STATUS,RP0 ; Bank 0
BCF ADCON0,ADON
CLRF PORTA_0002
CLRF PORTC_0002
CLRF PORTA_001
CLRF PORTC_001
CLRF PORTA_005
CLRF PORTC_005
CLRF PORTA_025
CLRF PORTC_025
CLRF PORTA_100
CLRF PORTC_100
CLRF BIT_MASK+0
CLRF BIT_MASK+1
CLRF BIT_MASK+2
BSF BIT_MASK+1,0
CLRF CONTROL_FLAG
BSF CONTROL_FLAG,0
CLRF DELAY_TIMER
INCF DELAY_TIMER
MOVLW B'00000111'
MOVWF CMCON
; Setup timer 1 and start
CLRF TMR1L
CLRF TMR1H
MOVLW B'00111001'
MOVWF T1CON
CLRF INTCON
BSF INTCON,PEIE
BSF INTCON,GIE
CALL INTERRUPT
MAIN_LOOP
