PIC 16f628a 7 seg. multiplexing
abdelmoneam
Joined Apr 23, 2013
how to multiplex 4 digit 7 segment on portb, knowing that one of the pins is used for ccp module as input, so whatever routine I use to write on portb this specific pin should not be altered, because changing the state of that bit in software will raise its interrupt flag.
Papabravo
Joined Feb 24, 2006
21,225
You make a table of PORTB outputs with ten entries that specify the output for each digit. Obviously the one bit must remain unchanged. Using another port you select which digit you want to light up and hold the PORTB lines in that condition for some period of time. It must be fast enough so you can't see the digits flicker.
ErnieM
Joined Apr 24, 2011
8,377
When you write to the register that controls a pin, be it the PORT or the LATCH register, if the pin is an input then your write has no effect on the pin's value.
Just leave the TRIS register alone.
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
for multiplexing you have to connect all segment of display together and the driving may be common cathode or anode with a bjt like
PORTD1=1;
PORTD2=0;
PORTD3=0;
PORTD4=0;
