pic 12f675 to light on led
Discussion in 'Embedded Systems and Microcontrollers' started by sovannarith, Feb 21, 2010.
  1. sovannarith
    Feb 11, 2010
    18
    Dear All
    I need your help. I try to begin my work with microcontroller. As last post I try to follow lesson on http://www.gooligum.com.au/tutorials.html but I have no pic 12f509 so I use 12f675 instead. After I write code as follow
    ; Description: Lesson 1, example 1 *
    ; Turns on LED. LED remains on until power is removed. *
    ; Pin assignments: *
    ; GP1 - indicator LED *
    list p=12F675
    #include <p12F675.inc>
    ; ext reset, no code protect, no watchdog, 4Mhz int clock
    __CONFIG _MCLRE_ON & _CP_OFF & _WDT_OFF & _INTRC_OSC_NOCLKOUT
    RESET CODE 0x000 ; effective reset vector
    movwf OSCCAL ; update OSCCAL with factory cal value
    ;***** MAIN PROGRAM
    ;***** Initialisation
    start
    movlw b'111101' ; configure GP1 (only) as an output
    tris GPIO
    movlw b'000010' ; set GP1 high
    movwf GPIO
    goto $ ; loop forever
    END
    And I build it success as follow
    Clean: Deleted file "C:\Documents and Settings\Sovannarith\Desktop\New Folder (4)\mypro01.cof".
    Clean: Deleted file "C:\Documents and Settings\Sovannarith\Desktop\New Folder (4)\mypro01.hex".
    Clean: Deleted file "C:\Documents and Settings\Sovannarith\Desktop\New Folder (4)\mypro01.mcs".
    Clean: Done.
    Executing: "C:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe" /q /p12F675 "12F675TMPO.ASM" /l"12F675TMPO.lst" /e"12F675TMPO.err" /o"12F675TMPo_O" /d__DEBUG=1
    Message[302] C:\DOCUMENTS AND SETTINGS\SOVANNARITH\DESKTOP\NEW FOLDER (4)\12F675TMPO.ASM 19 : Register in operand not in bank 0. Ensure that bank bits are correct.
    Warning[224] C:\DOCUMENTS AND SETTINGS\SOVANNARITH\DESKTOP\NEW FOLDER (4)\12F675TMPO.ASM 24 : Use of this instruction is not recommended.
    Executing: "C:\Program Files\Microchip\MPASM Suite\mplink.exe" "..\..\..\..\Program Files\Microchip\MPASM Suite\LKR\12f675.lkr" "12F675TMPo_O" /u_DEBUG /z__MPLAB_BUILD=1 /z__MPLAB_DEBUG=1 /o"mypro01.cof" /M"mypro01.map" /W
    MPLINK 4.30.01, Linker
    Copyright (c) 2009 Microchip Technology Inc.
    Errors : 0
    MP2HEX 4.30.01, COFF to HEX File Converter
    Errors : 0
    Loaded C:\Documents and Settings\Sovannarith\Desktop\New Folder (4)\mypro01.cof.
    Debug build of project `C:\Documents and Settings\Sovannarith\Desktop\New Folder (4)\mypro01.mcp' succeeded.
    Language tool versions: MPASMWIN.exe v5.30.01, mplink.exe v4.30.01
    Preprocessor symbol `__DEBUG' is defined.
    Mon Feb 22 11:21:36 2010
    BUILD SUCCEEDED
    The question is that when I compile it to pic and I try to construct circuit to light on the led It still not work. Could you advise me on such problem?
    Thank
  2. retched
    Dec 5, 2009
    5,201
    313
    did you program the hex to the pic? I only see where you compiled and converted to HEX. But I do not see that you wrote the HEX file to the PIC. Did the pic program successfully?
    Which PIC hardware programmer are you using?
    Are you attaching the led and resistor to the GP1 pin you have set?
    measure your output pins with a meter and see which ones are putting out 5v and which ones are 0v. Measure with the red lead, and put the black lead to ground.
  3. sovannarith
    Feb 11, 2010
    18
    sorry I confuse saying that I used pic12f675 infect now I just have pic 16f876. First I try to use pic12f675 but I use picket2 programmer so there is no device selected in baseline from this programmer so I try to use pic 16f876 but I don't know much about this pic 16f876 cause it big large especially oscillator part.
    I'm sorry with something unclear I'm saying to you cause I just start to curious with microcontroller. But I just want to start the simple project with my picket2 programmer applying with MPLAB for my beginning. So hope you can help me to overcome this difficulty.
    Thank
  4. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    You need an external oscillator on that PIC.
  5. AlexR
    Jan 16, 2008
    735
    54
    One thing to check (since you have enabled the MCLR pin) is have you pulled up the MCLR pin to Vdd via a resistor. If MCLR is configured to be on then without MCLR being pulled up the chip won't work.
  6. AlexR
    Jan 16, 2008
    735
    54
    I just re-read the thread and now I am totally confused.
    Just which PIC chip type are you using?
    Does your code match whatever PIC will be used?
    Does it compile without error?
    Can we see the code to match your PIC type?
    Also PICkit2 can in fact program the 12F675 but you will find it in Mid-range devices rather than the Baseline.
  7. sovannarith
    Feb 11, 2010
    18
    I use pic 16f876. And the code as following
    ;Dbt_sw2led
    ;Moves state of front microswitches to diagnostic leds.
    ;If both switches on then buzzer goes on.
    ;TJW 24.3.05 Tested & working 20.8.05
    list p=16f876
    include p16f876.inc
    ;Specify RAM labels
    delcntr1 equ 20 ;used in delay SR
    delcntr2 equ 21
    ;Set Configuration Word: crystal oscillator HS, WDT off,
    ; power-up timer on, code protect off, LV Program off.
    __CONFIG _CP_OFF & _RC_OSC & _WDT_OFF & _PWRTE_ON & _LVP_OFF
    org 00
    ;Initialise
    start
    bsf STATUS,5 ;select memory bank 1
    movlw B'10000000'
    movwf TRISC ;port C bits
    bcf STATUS,5 ;select bank 0
    main
    clrf PORTC
    bsf PORTC,6
    bcf PORTC,6
    bsf PORTC,6
    here goto here
    end
    After build it shows
    Clean: Deleted file "C:\Documents and Settings\Sovannarith\Desktop\New Folder\LED.err".
    Clean: Deleted file "C:\Documents and Settings\Sovannarith\Desktop\New Folder\LED.lst".
    Clean: Deleted file "C:\Documents and Settings\Sovannarith\Desktop\New Folder\mypro.cof".
    Clean: Deleted file "C:\Documents and Settings\Sovannarith\Desktop\New Folder\mypro.hex".
    Clean: Deleted file "C:\Documents and Settings\Sovannarith\Desktop\New Folder\mypro.mcs".
    Clean: Done.
    Executing: "C:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe" /q /p16F876 "LED.ASM" /l"LED.lst" /e"LED.err" /o"LED.o" /d__DEBUG=1
    Message[302] C:\DOCUMENTS AND SETTINGS\SOVANNARITH\DESKTOP\NEW FOLDER\LED.ASM 24 : Register in operand not in bank 0. Ensure that bank bits are correct.
    Executing: "C:\Program Files\Microchip\MPASM Suite\mplink.exe" "..\..\..\..\Program Files\Microchip\MPASM Suite\LKR\16F876.lkr" "LED.o" /u_DEBUG /z__MPLAB_BUILD=1 /z__MPLAB_DEBUG=1 /o"mypro.cof" /M"mypro.map" /W
    Errors : 0
    Errors : 0
    Loaded C:\Documents and Settings\Sovannarith\Desktop\New Folder\mypro.cof.
    Debug build of project `C:\Documents and Settings\Sovannarith\Desktop\New Folder\mypro.mcp' succeeded.
    Mon Feb 22 15:52:05 2010
    BUILD SUCCEEDED
    I use programmer picket2 to compile to pic 16f876. And after compile it highlighted that: Programming Successful.
    But when I try construct hardware it doesn't work, led not on on portC
    [​IMG][​IMG]
    [​IMG][​IMG]
  8. t06afre
    May 11, 2009
    5,939
    1,222
    The code do not match the 16f876 at all. In order to understand your PIC MCU, you must get an overview of the MCU architecture. You should download the data sheet for this purpose. Have you done any PIC work before, are you familiar with topics like bank switching etc? Also what do you use as clock source?
    You have a PICKIT 2 and that it is good start.
  9. sovannarith
    Feb 11, 2010
    18
    Sorry as I'm just a beginner of using pic so I try to read many books but It bit difficult with real practice. So could you give me some code for using pic 16f876 with picket2.
    Thank
  10. t06afre
    May 11, 2009
    5,939
    1,222
    Do not worry we have all been new sometimes. Can you please download this document http://ww1.microchip.com/downloads/en/DeviceDoc/30292c.pdf Then go to section 12 SPECIAL FEATURES OF THE CPU. Then let us start with the topic Oscillator Configurations. What have you connected to the OSC1 and and OSC 2 pins
  11. Markd77
    Sep 7, 2009
    2,803
    594
    If you decide to go back to the 12F675 you need to disable the analog features to use the pins as digital inputs or outputs. Example 3-1 in the datasheet shows you how.
    Also the osccal part in your code needs changing - see example 9-1.
    I like the 12F675 - fairly powerful for a small chip.
  12. sovannarith
    Feb 11, 2010
    18
    Dear All
    could you give me some simple code using with pic 16f876.
  13. t06afre
    May 11, 2009
    5,939
    1,222
    You need to build your self a simple trainer. I guess you can use the low pin count demo board as a template. you find it here http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en023805 look for "Low Pin Count User's Guide" But in order for this to work you must include a crystal or a RC osc in your design. It is also very important that you read section 12.1 Configuration Bits. The configuration bits must be correct for your setting. You can set them with the __CONFIG statement or from MPLAB. But you can NOT use the same settings as for the 16f690 chip used in the demo board. You will find the __CONFIG options at the end of the header file.
    Another solution is that you get a 16f690 chip and just build the trainer and use the demo code
