Hi
I need to design an electronic circuit for a PI controller for temperature.
I need to control 2 actuators 24Vac with input command 0-10V, one for cooling and the other for heating.
For measuring temperature I have to use 2 temperature sensors, one for measuring room temperature and the other for measuring and limiting the supply air temperature. (Practically I need a loop with two PI controllers - the setpoint for the room should decide the setpoint for the supply temperature which should be controlled by modulating the 2 actuators).
I have to make this only in theory and with analog parts, not by programming.
Do you have a circuit example with something similar?
I am very new to this and unexperienced and any help would be welcomed.
Thank you!
George
Thank you!
George
