PI Filter Design
Discussion in 'General Electronics Chat' started by sudharshan.panduranga, May 13, 2008.
  1. sudharshan.panduranga
    Thread Starter Active Member
    Apr 10, 2008
    61
    Sirs,
    pls find the attached schematic for PI filter calculation
    Regards,
    Sudharshana
    • PI.zip
      File size:
      12.1 KB
      108
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Is this supposed to be just for hgmjr, or for everyone to comment on?
    It is confusing to post a thread with someone's name called out in it.
    If it is just for hgmjr, perhaps you should send hgmjr a message instead?
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Greetings Sudharshana,
    Sgtwookie is right. I have editted out the reference to my user_id to avoid any confusion.
    It would be helpful for all if you would take a moment and describe in as much detail as possible the parameters that you need your power supply to meet.
    hgmjr
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    Can you give us the part number and manufacturer of the transformer T1?
    Harry
  5. sudharshan.panduranga
    Apr 10, 2008
    61
    Actually the transformer is custom built one.The core what am using is EF20
