physics projects
Discussion in 'Physics' started by wire, Dec 26, 2011.
  1. wire
    Dec 18, 2011
    13
    Guys........I need a suggestion on physics projects (modals) related to .....capacitors , electromagnetic waves , light or resistors which can be displaced for BSE level but not too complicated as it is not major subject .
  2. R!f@@
    Apr 2, 2009
    8,791
    771
    Did you try Google?
  3. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
  4. wire
    Dec 18, 2011
    13
    The reference site was quite useful.The problem is that I am running short of time I need I project which can be displayed .....the topic I have studied are about capacitors,resistance,electricity,electromagnetic waves....circuits....All experiment I have seen I think they can not be tagged as projects......I need some proper but simple to implement project....
  5. Sparky49
    Jul 16, 2011
    835
    417
    You could investigate the construction and use of a simple time domain reflectometer.
    I'll breifly explain what one is.
    If you have a long length of buried cable (we're talking into the hundreds of meters long) which transmits data, you're in a spot of bother if it becomes damaged because of a short circuit, a cut, water etc...
    You can't really justify digging up hundreds of meter of cable to find one fault, especially if it's in a residential area - think of all the complaints!:D
    Instead you can exploit an interesting effect - that some energy will reflect from the damaged part of the cable, back towards the emitter!
    This is what a time domain reflectometer (TDR) relies upon. At a basic level, it emits a large pulse of energy and waits for the reflection. You can time how long it takes for the pulse to go out and be reflected. With a bit of maths you can figure out where the damage is (to within a few meters!).
    Resistance and capacitance are covered nicely as both resistors and capacitors are used to generate the out going pulses - and can be used to vary the length of the pulse.
    Electricity is covered because - well - it runs off the stuff. Also, it ties in nicely with electricity in communications.
    If this suits you, I can provide a website with some more infomation to get you started.
    But you'll have to say please first!:)
    Sparky
  6. studiot
    Nov 9, 2007
    5,005
    515
    What's BSE level please, I thought BSE was mad cow disease :eek:
    There were a couple of good articles on this in a recent Elektor magazine including a practical project to follow.
    Metal detectors, cable detectors etc are also good for practical projects.
    Also visit this site
    www.physicsforums.com
    go well
  7. wire
    Dec 18, 2011
    13
    please ..... but i hope it will not be too complicated......as I think it will be.Would I be able to implement it.
    I was thinking to make a working model. ...using vegetable to generate electricity to lit a led to make traffic light but I think your idea will be a better choice.
  8. wire
    Dec 18, 2011
    13
    I can implement the circuit which I have seen .It involved oscilloscope and source generator. I have to study alot for understanding its working.Physics is not my major subject.I am doing software engineering.I think now you would be understand that I have only surface knowledge of physics.The site is
    http://www.epanorama.net/circuits/tdr.html
    Sparky49 likes this.
  9. Sparky49
    Jul 16, 2011
    835
    417
    The time domain reflectometer is probably simpler than the traffic lights circuit.
    Vegetable batteries are such a - cliche. They've been done and done and done and done and done and....
    Here's the link,
    http://www.free-circuit.com/time-domain-reflectometertdr-circuit-with-74ac14/
    Also, as studiot says, there are a few recent articles from elektor, which can be bought for virtually nothing. Regardless of their cost - they'll help you produce a brilliant project.
    Here's the link to the first article, discussing the whole idea of time domain reflectomy:
    http://www.elektor.com/magazines/2011/october/time-domain-reflectometry.1948603.lynkx
    And here's another about making the actual TDR:
    http://www.elektor.com/magazines/20...cilloscope-into-a-reflectometer.1992172.lynkx
    Again, I really recommend buying these two articles - they'll help you make a project your teachers goes 'wow'!:eek:
    I hope there's enough links to help you - "that's the power of please kids!"
    Sparky
    P.S. If you want any more help, don't be afraid to ask!
    P.P.S. I guess you are taking a GSE?
  10. Sparky49
    Jul 16, 2011
    835
    417
    Good website - I was looking for that one! :)
    Have a look at the Elektor articles - what part of the world are you from?
