Physics electricty and magnetism
Discussion in 'Homework Help' started by Mikee32, Mar 13, 2016.
  1. Mikee32
    Mar 13, 2016
    9
    Please use superposition method,
    the question is in the picture too :) 20160310_105314.jpg
  2. WBahn
    Mar 31, 2012
    18,080
    4,917
    Please show YOUR best attempt to work YOUR homework.
  3. shteii01
    Feb 19, 2010
    3,500
    511
    How much does this job pay?
  4. Mikee32
    Mar 13, 2016
    9
    This is it, please can u tell me if its right thanks
  5. WBahn
    Mar 31, 2012
    18,080
    4,917
    Without looking at the details of your work, your final answers agree closely with what I expect by inspection.
    You need to do a better job of tracking your units, though you are making a significantly better effort than most.
    You also need to be careful about polarities. It just happens that the two currents add because it just happens that they are flowing in the same direction. But nothing in your work indicates that you would have done anything different if, for instance, the current source had been sourcing current downward instead of upward. You need to clearly DEFINE the quantities you use -- and that means that when you define the current in the 10 kΩ resistor that you define what direction that current is flowing in.
  6. Mikee32
    Mar 13, 2016
    9
    Thank you so much !!! Honestly thank you, it's worth 20% of my module
