what do you think the circuit of this load http://eko-eu.com/products/photovoltaic-evaluation-systems/i-v-tracers/mp-410-mppt-electric-load
And you think that $180 is expensive????what do you think the circuit of this load http://eko-eu.com/products/photovoltaic-evaluation-systems/i-v-tracers/mp-410-mppt-electric-load
yes , it's for meAnd you think that $180 is expensive????
I think that the electronic load you posted the link to will cost ten times what the resistor costs...yes , it's for me
i didn't ask how to buy it , i asked if i can do it .I think that the electronic load you posted the link to will cost ten times what the resistor costs...
Yeah parallel a few mosfets in a bucket of oil or on an extruded aluminum heat sink and operate them in linear mode.i didn't ask how to buy it , i asked if i can do it .
why four NFETS and four resistors , as i saw in datasheet of IRF530 its PD equal 88 watt . ?Next, I present a sim of a crude but workable electronic load for your panel. The panel model is the same as in the previous simulation.
Here the independent variable of the simulation is the position of the pot, U2. The dependent plots show the panel voltage (green), panel current (red), the power dissipation in one of the NFETS (blue), and the power dissipation in one of the source resistors (violet).
Note that the power in the source resistors R1-4 peaks at 5W each, so you should use 10W resistors. The power in the NFETs peak at 34W each, so you should use TO220 style NFETs bolted to a very large metal plate heat sink. Note that the drains of the four NFETs are electrically common, so no insulating kit need be used under the NFETs, but the heatsink plate will be tied to the Panel+.
The sum of the power dissipated in the four resistors R1-4 and the four NFETs M1-4 is the same as the peak power delivered by the panel...
You need to learn about thermal derating. If you read the data sheet fine print, you will learn that it can dissipate 88W if the package is at 25degC. When you bolt it to a heatsink, the temperature of the heatsink (depending on its surface area) will rise.why four NFETS and four resistors , as i saw in datasheet of IRF530 its PD equal 88 watt . ?
Are you wanting to vary the resistance with a micro controller or by just turning the pot shaft? Since in your original posting you bought a pot, I assumed the latter.and how will i control the resistance and vary it with 1 ohm step ?
R1 was being varied in the first simulation; not the second.and why did you connect just R1 to U1 ? you said that you vary R1 and i see that it is fixed at 1.5 ohm.
how could you vary R1 in first simulation i think it's also constant as both of two simulations have same configuration .Like I said, your heatsink area will be need to be huge, likely in excess of 1 square m., or you will need a blower, or you will need to immerse it in water or oil...
The configuration of the opamp and the NFET is a constant-current-sink. The opamp adjusts the gate voltage of the NFET to create a voltage drop across the source resistor R1 to create a current through R1 proportional to the pot position. I am assuming that the other three NFETs M2-4 have Ids vs Vgs curves similar to M1, so that they share the current equally...
In the second simulation, the 10KΩ pot-wiper is moved from 0% to 100% in steps of 2.5%.
It is a simulation, therefore I can vary anything I want to...how could you vary R1 in first simulation i think it's also constant as both of two simulations have same configuration .
Then use a linear 10K pot.yes , i want to vary the resistance using pot.
Look at the blue trace on the second simulation plot again. That is the dissipation in the NFET M1 (Watts) as a function of pot position. You cant "control" it; it is what it is...you said that FETs dissipated power is 34 watt , how did you assume that ? from simulation and how to control that ?
Yesand i got that varying the pot will vary current of FETS consequently its resistance , am i right ? if so what is the range of variation .
At the worst case (near MPPT), 20W is dissipated in the four resistors R1-4 and 136W is dissipated in the four NFETS, for a total panel power output of ~150Wfinally which resistors will be the load .
Yes. I have worked with enough panels so I was able to just cobble it up on the fly:Mike, where did you get that nifty LTSpice solar panel model? How can I get one? Did you make it yourself?
I need to vary the resistance around 10 ohm at mpp with sensitivityFolks have told you over and over that the simplest load you can use is light bulbs. They are purpose-built to dissipate heat and provide visual feedback while being incredibly cheap and convenient. Another option is a heater element immersed in water.
edit - Aww nuts, I see Mike has already described exactly this scheme, more or less.
More like 5Ω.I need to vary the resistance around 10 ohm at mpp with sensitivity
0.2 ohm , how could i do that with light bulbs ?
ok i will use light bulbs instead of resistors but should i take their operating voltage into account i think that automotive light bulbs work on 12 Vdc .Use the current control scheme Mike showed earlier - where voltage across a known shunt provides feedback for the control op-amp. The light bulbs are merely an inexpensive alternative load to use instead of costly resistors.
Don't think of it as controlling ohms - you'll control current and let the circuit provide whatever ohms are needed to do the job. You can calculate the effective ohms based on current and voltage drop.
do you mean the sensitivity is 5 Ω ?More like 5Ω.
by Jake Hertz
by Aaron Carman
by Aaron Carman
by Aaron Carman
