photovoltaic panel load problem
Discussion in 'The Projects Forum' started by mah, Oct 31, 2013.
  1. mah
    Thread Starter Active Member
    Mar 15, 2010
    276
    i have photovoltaic panel max 150 watt , i want to put a potentiometer around 20 ohm to be its load . could you propose a solution .
  2. wayneh
    Sep 9, 2010
    12,373
    3,225
    Get out your credit card. They're not cheap.
    There are better ways to make a dummy load. What are you trying to do?
  3. MrChips
    Oct 2, 2009
    12,624
    3,451
    Why do you want to do this?
    Is the 20-ohm pot rated to handle 150W ?
  4. mah
    Mar 15, 2010
    276
    i want to measure current and volt at maximum power by changing the load resistance using potentiometer.
  5. strantor
    Oct 3, 2010
    4,302
    1,989
    how about parallel a few mosfets on an extruded aluminum heat sink and operate them in linear mode?
  6. mah
    Mar 15, 2010
    276
  7. strantor
    Oct 3, 2010
    4,302
    1,989
  8. mah
    Mar 15, 2010
    276
    will that give me a control in resistance around 20 ohm ?
  9. mah
    Mar 15, 2010
    276
    why won't it work ?
  10. strantor
    Oct 3, 2010
    4,302
    1,989
    you want to dissipate 150W. your pot is rated 1W. you will need a pot with 15,000% higher power rating than the one you have.
  11. MrChips
    Oct 2, 2009
    12,624
    3,451
  12. MrChips
    Oct 2, 2009
    12,624
    3,451
    Or get a whole bunch of 12V automotive headlight lamps and wire them in series/parallel combination.
  13. mah
    Mar 15, 2010
    276
    so what to do ? isn't there resistors with high power ratings , i will also need another one when connecting dc-dc converter.
  14. strantor
    Oct 3, 2010
    4,302
    1,989
  15. #12
    Nov 30, 2010
    16,665
    7,313
    I'm getting similar answers at Mouser. $180
    Headlights are a lot cheaper, especially at automotive dismantling and recycling emporiums.
  16. MikeML
    Oct 2, 2009
    5,450
    1,066
    Get a bunch of 10W to 50W wire-wound power resistors. Fill a plastic bucket with water. Immerse the resistors in the water. As long as the resistors are submerged in water, they can dissipate about 10X to 20X their rated power. Even if the water boils the resistors will be no hotter than ~100deg C....
    Automotive engine oil in the bucket can also be used. Dont burn yourself with the hot oil...
    When I started, we used to mount metal-jacket 6L6s upside down in water or oil and get 100W of RF on 40meters out of them.
  17. mah
    Mar 15, 2010
    276
  18. #12
    Nov 30, 2010
    16,665
    7,313
    Light bulbs.
    Incandescent light bulbs are just resistors designed to operate at very high temperatures.
  19. mah
    Mar 15, 2010
    276
    will i get the required resistance around 20 ohm ? i need to change it by 1 ohm .
  20. strantor
    Oct 3, 2010
    4,302
    1,989
    how about parallel a few mosfets in a bucket of oil and operate them in linear mode?
