Phototransitor -USB
Discussion in 'The Projects Forum' started by ledboy, Mar 20, 2012.
  1. ledboy
    Mar 20, 2012
    Hello! I can help you connect phototransitors to USB? I just connect to the date + and data- in series? Thanks
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Are you asking for assistance or are you offering assistance? Your wording is unclear on this point.
    hgmjr
  3. wayneh
    Sep 9, 2010
    12,384
    3,241
    Assuming you're asking a question, the answer is no. The bare transistor can produce only an analog signal, and USB requires a digital signal. There are USB devices such as a LabJack or DataQ that can perform analog-digital conversion, but you may not be happy with the cost (>$50).
  4. ledboy
    Mar 20, 2012
    I see. I guess that is an analog signal, but was not sure. Can you give more details LabJack or DataQ ? I want to build an IR touch screen. Thanks
  5. wayneh
    Sep 9, 2010
    12,384
    3,241
    Google is your friend. You'll find all the details you want.
  6. ledboy
    Mar 20, 2012
    If you mean multi touch screen, I tried! But I did not find anything on Google, no circuit diagram. Maybe I have not looked too technical. Finally, a LabJack I could help make a multitouch screen? LabJack see that could be made ​​easier at home, on a PCB.
