phototransistor
Discussion in 'The Projects Forum' started by bwaley, Jun 17, 2008.
  1. bwaley
    Jun 1, 2008
    27
    I have a three pin phototransistor and have designed a circuit using a two pin(i.e without the base) how can I do the connection this being the only availlable phototransistor as of now?
    Help me identify the pins( hint it has a tag).
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Can you supply us with a part number for your phototransistor?
    hgmjr
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The tag is the flag on a TO-18 can that identifies the emitter lead. The next closest lead is the base, and is not usually used with a phototransistor. The remaining lead is the collector. Base current is pretty weenie, so use a large resistor in the collector current for a good signal swing - something like 47 - 100K.
  4. bwaley
    Jun 1, 2008
    27
    further , should I connect the base or leave hanging?
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Leave the base unconnected.
  6. hgmjr
    Jan 28, 2005
    9,030
    214
    If you can provide a part number it would make it easier to provide more assistance.
    hgmjr
