Phototransistor
Discussion in 'General Electronics Chat' started by Alasttt, May 13, 2015.
  1. Alasttt
    May 13, 2015
    68
    Hi All,
    Ive got a question on phototransistors. Im attempting to shine a flashing led onto a phototransistor and get the digital output from the transistor. Is there a maximum frequency that the phototransistor can react at reliably ?. For example i I did 5 flashes a second, can I expect it to output the 5 pulses accurately ?
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Depending on how it is biased, a photo transistor should follow the flash rate up to hundreds of kHz and maybe even low Mhz.
  3. Alasttt
    May 13, 2015
    68
    Thanks thats better than i expected. So if I connected it forward bias, And I flashed an LED at it at a rate of 20khz say, representing 010101 etc. Would the output of the transistor be outputing 10101 at the same freq of 20khz?
  4. gerty
    Aug 30, 2007
    1,154
    304
    The data sheet on the components can give you all the operating characteristics. If this is on a breadboard you might encounter some stray capacitance that would have an effect on your circuit.
  5. MrChips
    Oct 2, 2009
    12,635
    3,453
    The devil is in the details such as circuit configuration.
    The maximum frequency will depend also on the frequency response of both the transmitter and the receiver. Frequencies in excess of 1MHz or even 100MHz is not unheard of.
  6. Alasttt
    May 13, 2015
    68
    Thanks. Would you expect the output of the phototransistor to be the same frequency as the led ?
  7. Alasttt
    May 13, 2015
    68
  8. MrChips
    Oct 2, 2009
    12,635
    3,453
    Of course the frequency would be the same and in synchronization? Why would it not be?
  9. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,692
    1,297
    A phototransistor is a simple energy converter. It has no signal or data processing capabilities. In the standard common emitter configuration it is inverting. That is, as the light intensity increases the voltage at the collector decreases. If the transmitter is a simple LED driver, then a logic 1 turns on the LED, which turns on the phototransistor, which makes a logic 0. Other than this simple inversion, there are no logic signal changes.
    Note that while what I described is a very simple system, biasing the phototransistor and shielding it from ambient light interference are critical to getting it to work properly. For example, a phototransistor sees a fluorescent light as a 120 Hz strobe light.
    ak
  10. Alasttt
    May 13, 2015
    68
    Thanks. I just had a feeling the transistor might not switch its output quick enough. I might want the distance between the LED and the phototransistor to be quite significant around a meter. Do you think transmitting it through a fibre would still mean the led and the photodiode can reach each other well enough ?
  11. Alasttt
    May 13, 2015
    68
    Hi thanks for your response. Do you think inserting the photo transistor into a fibre would prevent it from being affected from ambient light?
  12. ian field
    Oct 27, 2012
    4,447
    791
    Can't remember the speed thresholds, but as a general rule; photo diodes are faster but less sensitive, while photo transistors are slower but more sensitive.
    If you can still get them - photo Darlingtons are even more sensitive - but even slower.
  13. WBahn
    Mar 31, 2012
    18,087
    4,917
    I think as a general rule for discrete parts this is pretty true. In the integrated world, however, it is entirely possible to use photodiodes to do single-photon event counting.
  14. ian field
    Oct 27, 2012
    4,447
    791
    That doesn't appear to be what the TS is trying to do.
  15. WBahn
    Mar 31, 2012
    18,087
    4,917
    Agreed. At the speeds that the TS seems to be talking about, it's hard to imagine any photonic device that can't respond quickly enough.
  16. ian field
    Oct 27, 2012
    4,447
    791
    Years ago I was messing about with a 10.7MHz ceramic filter and decided to add an FM radio IFT to make a proper oscillator.
    It didn't seem to be doing a lot, so I added an inverse-parallel pair of red LEDs across the secondary pins - there was a barely visible glow on the die inside each LED, and it blotted out my FM reception.
  17. Alasttt
    May 13, 2015
    68
    Right thanks. My data light source is 20khz. This however gives a wavelength of 15km which is huge. Looking at datasheets for some phototransistors, most of them are optimal at around 1000nm which is way off 15km. Hence why I am concerned . Comments?
  18. bertus
    Administrator
    Apr 5, 2008
    15,801
    2,387
    The 20 kHz is most likely the modulation frequency, wich is completely different to the IR wavelenght.
    The carrier ferquency will be the one of the IR wavelenght.
    Bertus
  19. Alasttt
    May 13, 2015
    68
    Yes the modulating frequency is 20khz. Im going to connect this to an LED and insert the led into a fibre. The carrier will then be light. Do I need to calculate the wavelength of the carrier then ? Which in this instance is light
  20. WBahn
    Mar 31, 2012
    18,087
    4,917
    A light source being modulated at 20 kHz in now way means that the wavelength of the light is 15 km. You are confusing very different concepts. The wavelength of the light is related to the color of the light. If you take a red laser pointer and flick it on and off, does the color change? Also, according to your reasoning, if you had a light source that was on continuously it would be DC and have an infinite wavelength. Does that make sense?
