Photosensitive resister On/Off Led circuit
Discussion in 'General Electronics Chat' started by kongway, Apr 12, 2007.
  1. kongway
    Apr 12, 2007
    12
    I try to design a circuit (attached is my design) , using photosensitive resister to automatically turn ON the Led, when here are dark. Otherise Led are OFF. But some barrier was occur, i don't know how to fix it. So if any body have idea, please advise me and give me opinions about my circuit and the component value.
    Thank a lot!
    Kongway
    Please find attached again
  2. kender
    Jan 17, 2007
    263
    Your attachment didn't get posted.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The image is very small and hard to make out. If the applied voltage is positive, the transistor is in cicuit with the emitter and collector reversed.
  4. kongway
    Apr 12, 2007
    12
    thank you beenthere,
    Actually, i don't know my circuit is work or not and push 3 Led on brightly. So can you please provide a circuit to me?
    Thanks again
    Kwongway
  5. electronics wiz
    Mar 15, 2007
    54
    you can use a compartor if you want, that would also let you ajust the circuit.
  6. kongway
    Apr 12, 2007
    12
    Thank you all
    i already found the circuit!
